Thread: Top Swap Cost (parts)
Results 1 to 17 of 17
  1. #1 Top Swap Cost (parts)
    SE Level Member Lionel's Avatar
    Moncton N.B.
    I see there are alot of top swap posts up ATM, Mine is different question
    I've called all the local junkyards around my area (Atlantic Canada). Only two of them had 2004 GTP's, and they are unwilling to sell me parts. The'll only sell me the engine as a whole. the cheapest I could find was a car (engine) with 87 000 KM's for 2400.00$ CAN.
    Which is Bull**** at that price I may as well save up for a brand new engine.
    My question is, what are my options? Can any of you find a junkyard that doesnt want to rip everyone off? if that's the case, I think even with shipping to canada It'd be well under 2000$.
    I really appreciate any help i can get, I'm leaning strongly toward a top swap.
  2. #2 Re: Top Swap Cost (parts)
    Willoughby, Ohio
    i found 3 whole L67 engines on craigslist by where i live for $300 or under, a gen V setup is gonna be at least $400 for just the supercharger...much more expensive
  3. #3 Re: Top Swap Cost (parts)
    You might as well try to find some stuff in the states with people willing to ship to Canada...that would be my best guess
  4. #4 Re: Top Swap Cost (parts)
    Moncton N.B.
    yeah I've been browsing the classifieds hoping... I wish ppl would just put the year of the car and make 2004 GTP tells me its S/C and gen 5. l67 and l26 is still confusing to me, still trying to memorise.
  5. #5 Re: Top Swap Cost (parts)
    You can put a GenIII on there you know that right? You just need a matched LIM and reroute your EVAP/Vacuum lines for the blower and use and adapter plate for the L32 Throttle Body...that should save you a good chunk of change.
  6. #6 Re: Top Swap Cost (parts)
    Moncton N.B.
    my buddy has a 97 gtp, that would be a gen III engine right? does that mean i could do the swap with his engine?
    if not can i use any of his parts to save me money?
    EDIT: i see after reading up, when you said gen III you meant the supercharger only, not the engine parts.
  7. #7 Re: Top Swap Cost (parts)
    You can literally use most of the L67 parts.
    just not the TB and fuel rail.
  8. #8 Re: Top Swap Cost (parts)
    Charles City, IA
    yup what matt said
    SMGPFC Two Nipple General
  9. #9 Re: Top Swap Cost (parts)
    Donating Users Storm's Avatar
    LaCrosse Wisconsin
    Some people will get lucky and do a Gen III top swap for $600 for everything, others can spend $1200 easily for a Gen V. It depends what you want.
    FOR SALE
    TOP SWAP PARTS- PM ME
  10. #10 Re: Top Swap Cost (parts)
    i spent $600 and got a full top swap, a cam, 130# springs, comp. push rods, and OER lifters. find the right deal.
  11. #11 Re: Top Swap Cost (parts)
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Thats a hell of a deal.
    As Nick said though, if you just watch the forums... deals do pop up.. Just gotta have the cash ready.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  12. #12 Re: Top Swap Cost (parts)
    GT Level Member DBGP's Avatar
    Vancouver, BC, Canada
    Yea I have a question too, I look at zzp's site for all the top swap parts (ported m90, modifed lower intake manifold, ss m90 kit, billet fuel logs, pulley.) I was wondering could I find a gtp in a wrecker or something and take the s/c and lower intake manifold and whatever else I need? Cause if I get it from zzp its gona be around 1700$ plus 300-400 for shipping
  13. #13 Re: Top Swap Cost (parts)
    Dude.... thats the way you're supposed to do it.
    Get everything from the heads up, the harmonic balancer and coil bracket and the one idler bracket that mounts to the block.
    It'd be MUCH cheaper than the SSM90 kit... which is not considering a true top swap by most around here.
    Cheapest way is to find someone local or a local wrecker to pull the parts from.
    Next bet is something like this: http://www.grandprixforums.net/f49/g...wap-32211.html
  14. #14 Re: Top Swap Cost (parts)
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by DBGP View Post
    I went with the zzp m90 kit, Was a easy install and went smooth, and I didnt have to worry about getting used heads. If you go zzp m90 send them a blower core and LIM core dont get fuel logs, you can make your own rails. I got the logs but they suck IMO. Constant leaking at the regulator. That will bring the price you quoted way down, think I payed like 1K and that was with like 300 into the fuel Logs
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  15. #15 Re: Top Swap Cost (parts)
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    ya im doing the ssm90 kit bought lim logs and ssm90 kit from zzp everything else was found used and i bought a regular m90 and just ported it and am using my dremel to cut out for the fuel injectors i probably have 1400 into this including shipping and lots of othere part oil orings gaskets paint etc probably could do this swap for 1200
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  16. #16 Re: Top Swap Cost (parts)
    ny
    Quote Originally Posted by Lionel View Post
    I ordered the top swap kit from morad for $1000 and the gaskets and other odds and ends were like another $200 I have my parts list if you want it. This was a gen V top swap. Be ready to do wiring into the pcm, rerouting of vacuum lines, pulling off the balancer, changing heads and LIM!
  17. #17 Re: Top Swap Cost (parts)
    lionel 97-03 is a gen 3 s/c with l67 engine 04+ is the l32 with gen 5 s/c
    if u want to go the cheap route get all the l67 parts except u will need the tb and fuel rail to be l32 so u will need an adapter plate from zzp or if u know someone who can make one u can do that and for $2400 u could do a turbo build if u got the money to
    sold 97 GTP stock
  1. Top swap parts
    By slednut in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2009, 11:19 PM
  2. cost of top swap
    By skidoojames151 in forum General Tech Discussion
    Last Post: 08-05-2009, 09:44 AM
