Thread: Timing Chain Replacement
Results 1 to 3 of 3
  1. #1 Timing Chain Replacement
    SE Level Member Traeger2591's Avatar
    IL
    Does anyone know where there is a write up on how to change the timing chain for a 99 gt? I searched all over and had a hard time finding one. If there's not a write up can someone help me out?
    I've got around 160k on my car and I figured it'd probably be worthwhile to change it. Thanks.
  2. #2 Re: Timing Chain Replacement
    Apr 2009
    stockton ca
    pull pass side tire
    pull balancer will need special bolt size 3 3" bolts for puller pull pulleys water pump and every thing blocking front cover
    pull front cover
    unbolt cam bolt slide timing set off
    align new timing set
    might as well replace water pump and oil pump since they are off any way
    re install all the carp taken off and enjoy
  3. #3 Re: Timing Chain Replacement
    IL
    Thanks. That's all I was needing to know haha.
  1. timing chain replacement question
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2010, 08:53 PM
  2. timing Chain
    By Zach3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2010, 11:12 PM
  3. timing chain
    By pure in forum General Tech Discussion
    Last Post: 08-16-2009, 02:00 PM
  4. Which timing chain to get.
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 09:01 AM
  5. Which timing chain?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 04:49 PM
