Thread: busted oil pan
Results 1 to 5 of 5
  1. #1 busted oil pan
    new york
    so yesterday i was driving to my buddys house and hit a very large rock on the way and it tore a whole in my oil pan under the car and the car started pouring out oil .... how hard is that to replace? / how much is it to get done at a shop? anyone have any ideas? i want to do it myself to save some cash but not if im gonna mess it up while fixing it if its really hard
    2002 GP GT - 180* T-stat, DIY 4"FWI, ZZP PLOG, 2.5" catted DP, DHP PCM, HV2,
  2. #2 Re: busted oil pan
    SE Level Member prixgt01's Avatar
    Schaumburg,il
    I have the same problem, bad oil pan but ine was rusted through. i bought the parts for about a 100 bucks and my buddy is putting it in for 300 bucks, he said its about a 5 to 7 hour job. alot of **** to do, losen the motor mounts tilt the engine and etc. good luck
  3. #3 Re: busted oil pan
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    you either have to pull the engine, or drop the subframe. some people say pulling the engine is easier. for a shop to do it you're looking at AT LEAST $500
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  4. #4 Re: busted oil pan
    I'd drop the subframe...I hate pulling motors even though it is easy as sh1t to do it when the motor is out.
  5. #5 Re: busted oil pan
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    drop the k frame..its really not as hard as people make it out to be. If you have a hoist and an impact that is lol
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  1. Busted piston!!!!
    By lambokit in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2013, 11:10 AM
  2. Busted!!!
    By offroadfury6 in forum Off Topic Discussion
    Last Post: 11-08-2009, 11:14 PM
  3. Busted St-11's need Replacing So..
    By SDGTP99 in forum Tires & Wheels
    Last Post: 10-16-2009, 02:12 PM
  4. Busted Front Swaybar
    By Pontiac Warrior in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 01:33 AM
  5. Window Busted Out
    By GreenPrix in forum Off Topic Discussion
    Last Post: 12-08-2008, 09:05 AM
