Thread: Falling mileage w/ new oxygen sensor.
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Falling mileage w/ new oxygen sensor.
    Feb 2008
    West Jordan, UT
    The PCV and fuel filter are both new. How can I test my EGR and injectors?
  2. #22 Re: Falling mileage w/ new oxygen sensor.
    Barksdale AFB, LA
    EGR can simply be cleaned. Injectors, you could connect a fuel pressure test gauge and prime the system. Then make sure it holds pressure.
    2009 Subaru Impreza WRX STI
  3. #23 Re: Falling mileage w/ new oxygen sensor.
    Feb 2008
    West Jordan, UT
    Can you tell me where the EGR is, and how to clean it? Would carb cleaner work?
    and how much should I expect to have to spend on a fuel pressure tester? I don't have one, and have never used one.
  4. #24 Re: Falling mileage w/ new oxygen sensor.
    Barksdale AFB, LA
    Quote Originally Posted by spenc938 View Post
    I wouldn't use carb cleaner on anything in my engine. It's very bad for sensors. TB cleaner would probably work. As far as where it is, it's to the driver side rear of the engine, a vertical looking cylinder with an electrical connector on top. If you don't have a Haynes/Chilton manual yet, you should get one.
    I don't know the exact price, but they're not expensive. It's just a pressure gauge with a fitting.
  5. #25 Re: Falling mileage w/ new oxygen sensor.
    GT Level Member mainecrab's Avatar
    Feb 2008
    Truly if you are only going 2 miles back and forth to school, should you really worry about spending so much on getting the milage above what it is now?
  6. #26 Re: Falling mileage w/ new oxygen sensor.
    Feb 2008
    West Jordan, UT
    That's only been because I haven't been working. When I start working again, which is next week, it will be between 20 and 30 miles a day.
  1. The alt rewire mod actually DOES increase fuel mileage!!
    By DanGTP in forum General Tech Discussion
    Last Post: 04-12-2012, 07:31 AM
  2. would hi-mileage/worn spark plugs cause KR at WOT/PE?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 08:15 AM
  3. high mileage trans issues
    By 01whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2008, 08:23 AM
