Thread: cam vs rockers
Results 1 to 20 of 24
  1. #1 cam vs rockers
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    ok well im trying to debate wheter it is worth it to put on cam or rockers a cam cost 345 shipped for a zzp gt2 cam or a set of 1.95 rr with springs and retainers cost 590 shipped wont i get the same gains from each 25 from a cam and 25 from the rockers and rockers cost alot less to install vs cam
    p.s im looking for a high stall converter anyone got one
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: cam vs rockers
    Apr 2009
    stockton ca
    topswap it man
  3. #3 Re: cam vs rockers
    Jersey
    Quote Originally Posted by TorqueAutoMotiv View Post
    topswap it man
    ^^what he said
    16' wrx sti- stock
  4. #4 Re: cam vs rockers
    GTX Level Member real diehl's Avatar
    Salina, KS
    Buy a GTP. You keep saying you want to go fast, but N/A isn't going to cut it. Topswap or buy a GTP. Boost is your friend here.
    signature removed for inappropriate content.
    -bio
  5. #5 Re: cam vs rockers
    well im gunna buy a gtp for boost but i want the n/a car i only wanna run 14s with this car the gtp will be my twin charged grocery getter i do not wannt top swap or i would have done it long ago lol keep the gas milage half decent not gunna get that with a boosted car i comute pretty far
    sold 97 GTP stock
  6. #6 Re: cam vs rockers
    Outer Space
    Cam i started with rockers..
    Cam all the way
    02 GTP 13.6 @ 100mph - SOLD
  7. #7 Re: cam vs rockers
    Apr 2009
    stockton ca
    cam it then no use in rockers
    a little N2O never hurt either
  8. #8 Re: cam vs rockers
    what is the horse power diff between 1.95 rr and a zzp gt2
    sold 97 GTP stock
  9. #9 Re: cam vs rockers
    Outer Space
    Good question.... i don't know the answer though. I got a s1x cam. I love it.
  10. #10 Re: cam vs rockers
    Cam will always out power rockers if that is the ONLY mod you do. Cam it and top swap it and run low 13;s
  11. #11 Re: cam vs rockers
    surprisingly enough, the GTx series of cams make decent blower cams as well. so if you want you can cam it now and then top swap it later.
  12. #12 Re: cam vs rockers
    Grand Island, Nebraska
    if you cam it, you are going to get worse gas mileage than if you top swap it. boosting it doesnt really hurt gas mileage unless you make the blower work (you push your car hard all the time)
  13. #13 Re: cam vs rockers
    Quote Originally Posted by JoRoW99 View Post
    That's not true...its all in the tune. I saw over 30 HWY with my XP/headers/LS1TB/3.2" or whatever pulley I was running.
  14. #14 Re: cam vs rockers
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    so then would a rockers/ intercooler/ 3.0 pulley be a bad combo or should i cam it with that setup... sorry for thread jacking but this is my goal for my gtp...
    2000 Daytona GTP(aka the slow fwd GTO)
  15. #15 Re: cam vs rockers
    im sorta leaning towars 1.95s eventhough id really like the cam its jus easyier to install
    sold 97 GTP stock
  16. #16 Re: cam vs rockers
    Jersey
    cam
    you'll get better numbers
    16' wrx sti- stock
  17. #17 Re: cam vs rockers
    the point is that hes not going to lose gas mileage with a top swap, at least not very much. hell you got better mileage than my gt.
  18. #18 Re: cam vs rockers
    also, if you are definitely going to stay NA, go with the ER rockers. they are better for NA cars than 1.95. if you read up on the article zzp has on them, they FAR outperform the 1.9s in the high rmp range.
    http://www.zzperformance.com/grand_p...=555&catid=104
  19. #19 Re: cam vs rockers
    I never said he was going to lose MPG's with a TS...you said the cam was going to net him worse MPG's and that isn't true. If the tune is bad, or richened up, then yes. If not...then it'll get just as good MPG's as a stock cam, if not better.
  20. #20 Re: cam vs rockers
    ZZ Performance
    ya but it balances out cuz of the torq diff 1.9s had better torq the the ers and wouldnt roller rockers be better?
    sold 97 GTP stock
  1. ZZP 1.9 Rockers in
    By Brooks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2009, 01:28 AM
  2. 1.9 rockers
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2009, 10:37 PM
  3. cam or rockers???
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 12-02-2008, 08:09 AM
  4. What rockers?
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-13-2008, 07:10 PM
