Thread: Fuel pressure and fuel in the rails
Results 1 to 7 of 7
  1. #1 Fuel pressure and fuel in the rails
    Hoffman/Schaumburg, IL
    Ok, with the recent running problems I've had with my car, I decided to ohm out the injectors, all checked out ok. 11.9-12.0 for all 6.... Then I decided to test if there was any pressure at the rail, I pushed in the shrader valve and nothing came out, so I got a small screwdriver and pushed it in further, still nothing, not even fuel smell seemed to come out, now my question is; would this be a sign of a bad fpr, a bad return on the pump side(i think it has a check ball right?), or is this normal for sitting over night
  2. #2 Re: Fuel pressure and fuel in the rails
    Bastard Reptile's Avatar
    Kansas City, MO
    Even sitting overnight it normally would have a little pressure, but it could also be normal.
    When the stock pumps get weak, they can also let things bleed off. When the FPR goes bad, you can take the vacuum line loose, and it may leak gasoline out of the fitting, or your pressure may be too low.
    A pressure test can tell a lot in a hurry. If you have a gauge screwed into the valve, when you pull the vacuum line the fuel pressure should spike. Normal fuel pressure at the rail is about 48-56psi at idle.
    I'd see about getting a Fuel pressure gauge to start and see where that leads you to.
  3. #3 Re: Fuel pressure and fuel in the rails
    Saraland Alabama
    that is usually a sign of a bad pump (they have an anti drain back) but I agree check pressure and see where you are. On another note, could an injector have some debris holding it open, and still ohm good?
  4. #4 Re: Fuel pressure and fuel in the rails
    Barksdale AFB, LA
    Could be a leaky injector letting the pressure go.
    2009 Subaru Impreza WRX STI
  5. #5 Re: Fuel pressure and fuel in the rails
    Yeah, ohming it only checks the coil
  6. #6 Re: Fuel pressure and fuel in the rails
    hangover park IL, in the garage working on one of 12 3800's
    did you pull the rail and check spray pattern?
    leave the fuel gauge connected and check it hourly, you should have ~10psi residual pressure, stuck open inj, leaking FPR seat or diaphram, or a bad antidrainback valve in the pump could cause it to drop
  7. #7 Re: Fuel pressure and fuel in the rails
    I'm 75% sure that my problem is a vac leak that I cant find, I need to get a gauge to check the FP, but It think it is a smaller and unrealted issue.....I hope
  1. anyone have a Prosport fuel pressure gauge?
    By fst in forum PCM Tuning
    Last Post: 04-02-2008, 06:38 AM
  2. Pressure Supply Fuel Line
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 03-26-2008, 10:08 PM
  3. Fuel rails
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2008, 05:46 PM
  4. PRJ Gen 3 fuel rails?
    Last Post: 02-10-2008, 02:42 PM
  5. After Market Fuel Pressure Regulator
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 02:14 PM
