Thread: L26 / L36 flexplate interchangeable?
Results 1 to 4 of 4
  1. #1 L26 / L36 flexplate interchangeable?
    Feb 2008
    San Diego, CA
    So the L26 has the powdered metal versus cast (?) rods of the L36, right?
    I imagine that would give the L26 rods a different weight?
    So then, is the L26 crankshaft different? (or weighted differently)?
    Ultimately, would the flexplates (flywheel) between an L36 and L26 be interchangeable?
  2. #2 Re: L26 / L36 flexplate interchangeable?
    GT Level Member TurboKent's Avatar
    Woodward, OK
    yes
  3. #3 Re: L26 / L36 flexplate interchangeable?
    Feb 2008
    San Diego, CA
    OK, here's a question. After digging around some more, I believe I read a post on this very forum stating that the 2005+ Series 3 flexplates (for L32, anyway) are "dual pattern" (i.e., drilled for both 245 and 258 mm torque converter). Can anyone confirm this? And does it apply to L26 also?
    Thanks
  4. #4 Re: L26 / L36 flexplate interchangeable?
    hangover park IL, in the garage working on one of 12 3800's
    it seems as only the 9C1 police package impala's have the dual pattern 3 window flexplate i have an 04 9C1 flex that has the 3 windows of the L67 flexplate but has both Tq conv patterns and i've seen/had a couple 04 and one 05 GTP's and none of those had both patterns...
  1. L26 Lifters and Flexplate in L67?
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2008, 12:13 AM
