Thread: Headlight Problems (Low beam)
Results 1 to 5 of 5
  1. #1 Headlight Problems (Low beam)
    Apr 2009
    San Antonio
    I'm having intermittant headlight problems where the low beams will cut off while driving down the road and won't turn back on. I have tried to pull over and turn the car off, restart, even pulled the neg. battery terminal to try and "reset" to no avail. The next day, the lights will work again.
    This has happened 3 times in the last 3-4 months (that I have noticed).
    From what I can find on the web, it is suggested to change the dimmer switch (the whole turn signal, cruise control, etc).
    Anyone have any experience with this? It is a 150.00 part so I don't want to change it unnecessarily.
  2. #2 Re: Headlight Problems (Low beam)
    GTP Level Member SuperSport's Avatar
    Michigan
    What year is your vehicle? The issue is probably the resistor on the top of the dash.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: Headlight Problems (Low beam)
    Aug 2011
    midwest
    I am having the same exact issue on my wifes 2006 GP ...her low beams will be working fine driving at night and may never happen for a week or so then all of a sudden the low beam will shut off and if she kicks the high beam on the high beams work fine .....She will leave the high beams on for a few minutes and periodically check to see if the low beams have come back on and eventually they do in about 5-10 minutes maybe even 15 minutes ...Please help...
  4. #4 Re: Headlight Problems (Low beam)
    Charles City, IA
    Mine did the same thing for a while, check the head light circuit breaker in the fuse block in the glove box, mine was loose and losing connection.
    SMGPFC Two Nipple General
  5. #5 Re: Headlight Problems (Low beam)
    Aug 2011
    midwest
    Thanks for your feedback ...I will check that glove box fuse ...
  1. High/Low beam simultaneously
    By hacket in forum Audio, Security & Visual Electronics
    Last Post: 01-23-2010, 10:37 AM
  2. Need High Beam, Low Beam, Fog wiring help...
    By TuKoolGTP in forum General Tech Discussion
    Last Post: 12-29-2009, 12:57 PM
  3. HID's: Lo/Hi beam reversed
    By Bedwards in forum Visual/Body Modifications
    Last Post: 11-03-2009, 01:49 PM
  4. New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    By GeddyLee in forum General Tech Discussion
    Last Post: 01-29-2009, 07:26 PM
  5. Hid with a high beam
    By crywolf in forum Visual/Body Modifications
    Last Post: 01-27-2009, 07:13 PM
