Thread: How are the 42# injectors?
Results 1 to 14 of 14
  1. #1 How are the 42# injectors?
    SE Level Member $03gp/gt$'s Avatar
    Feb 2008
    Chillicothe/Peoria IL
    I just heard of the 42# injectors tonight. I was wondering what are the results on putting these injectors in and if you need a flashed pcm to have these injectors. ZZP doesn't have a description of the specs and what u need to have these injectors. Help me out guys.
  2. #2 Re: How are the 42# injectors?
    May 2008
    McHenry IL
    im curious 2 good q
  3. #3 Re: How are the 42# injectors?
    Charles City, IA
    Yes you need to reflash the pcm for them and you do not gain hp from injectors.
    SMGPFC Two Nipple General
  4. #4 Re: How are the 42# injectors?
    Feb 2008
    so whats the big deal about them?
  5. #5 Re: How are the 42# injectors?
    Charles City, IA
    You need them when you are past about a 3.2 setup to meet the fueling needs. The only time they will let you make more power is if you are out flowing your stock ones and need bigger ones to inject more fuel.
  6. #6 Re: How are the 42# injectors?
    Feb 2008
    gotcha coo man thanks
  7. #7 Re: How are the 42# injectors?
    Also...what is the point since your N/A?
  8. #8 Re: How are the 42# injectors?
    I lawled.
    Someone once told me to get injectors since that would definatley give me more power...
  9. #9 Re: How are the 42# injectors?
    On most boosted cars that IS the case...especially with a tune...but then the injectors aren't giving you more power they are just giving you more fuel so you can mess with the tables, timing, and boost...which is where you make your powah
  10. #10 Re: How are the 42# injectors?
    I dont have boost.
    Hence the hilarity of the situation.
  11. #11 Re: How are the 42# injectors?
    Charles City, IA
    I dont have boost.
    Maybe they thought you had a diesel.
  12. #12 Re: How are the 42# injectors?
    nebraska
    If your going with bigger injectors you mise as well get a smaller pulley also.. I have 42's but I have an slobalt so my opinion don't matter lol
  13. #13 Re: How are the 42# injectors?
    Jul 2008
    sumter,south carolina
    lol
    02 GTP with mods 05 GP for DD
  14. #14 Re: How are the 42# injectors?
    Theres perhaps a grand worth of parts you have to spend before you even need bigger injectors with our cars.
  1. What do I do with my injectors?
    By FuglyGTP in forum General Tech Discussion
    Last Post: 04-01-2009, 02:12 PM
