Thread: SS M-90 belt wrap solution!!
Results 1 to 9 of 9
  1. #1 SS M-90 belt wrap solution!!
    Donating Users chico's Avatar
    04 gto stock,97 GPGT l-36 block diamond pistons ,l-32 rods ,custom comp cam grind,HS 1-7 RR, p&p heads, SS IC,SS M-90 3.5" ,4t60eHD,from Gonzales TX.
  2. #2 Re: SS M-90 belt wrap solution!!
    Oklahoma
    That has some serious promise I would think. Very nice dude. Any way it could possible be pushed down even further?
    Also, where did you get those ignition coils from?
  3. #3 Re: SS M-90 belt wrap solution!!
    Yes I could give it a bit more wrap if I went to a 1" longer belt and drilled another hole in the bracket,this was a first attemp so a little experimenting is in order,as far as the coils I picked those up in Canada.Chico.
  4. #4 Re: SS M-90 belt wrap solution!!
    Topeka, KS
    Care to post pics for the people who are banned from CGP.
  5. #5 Re: SS M-90 belt wrap solution!!
  6. #6 Re: SS M-90 belt wrap solution!!
    SE Level Member 1998gpgt's Avatar
    McHenry, IL
    I asked this over on CGP as well but.... What size SC pulley do you have on there now, the 3.5"? Is that idler 3" or 3.5", and would there be room to use a larger pulley to get even more wrap?
    1998 Grand Prix GT 337whp/363wtq 12.952 @ 112.02
    2000 Grand Prix GT & 2007 Grand Prix GT
    2004 GTO 13.610 @ 102.69
    1985 Cutlass 455/TH350
  7. #7 Re: SS M-90 belt wrap solution!!
    There is probably enough room to use a 3.5 idler pulley,this is just the initial design I will try to lower the pulley for a lttle more wrap.
  8. #8 Re: SS M-90 belt wrap solution!!
    Here is the 2nd edition a shortened bracket and a March billet pulley.
  9. #9 Re: SS M-90 belt wrap solution!!
    Oklahoma
    WOW dude, that is really nice. You should put sets of these together and sell them.
  1. Serpentine Belt Size's [*]
    By WasteU in forum How To Write-Ups/Tech Tips
    Last Post: 11-08-2013, 03:31 AM
  2. Drive Belt Replacement [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 05-24-2009, 05:44 PM
  3. too small of a s/c belt???
    By IndeedSS in forum General Tech Discussion
    Last Post: 03-31-2008, 03:06 PM
  4. Intake & exhaust wrap?
    By maybe_memories in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-10-2008, 05:12 PM
  5. pulley belt from zzp
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2008, 03:09 PM
