Thread: Intake manifold & Water pump help
Results 1 to 10 of 10
  1. #1 Intake manifold & Water pump help
    SE Level Member Wraith888's Avatar
    Twin Cities
    I have a 2000 GT with ~140k miles on it. I really like this car and I'm happy with it overall, but I'm posting all the issues I have in hopes I can get help, so it might sound like I'm complaining, but I'm asking for help.
    I live in an apartment and I don't own any tools, so I took it to a dealer to have them change the oil & do the recall work. They told me that their mechanic observed antifreeze leaking from the water pump and lower intake manifold.
    I know my car is leaking antifreeze and using some oil and I also have observed when I'm idling that I can smell exhaust (not sure if that's related or not) and every once in awhile it will idle like it's missing (maybe a spark plug issue?). Finally, I also observe the car whines really high-pitched when it accelerates. (That could be just how the car is made however, nobody else has remarked that it's sounding strange).
    The dealer told me they will do the lower intake manifold for $600-$1000 parts and labor and the water pump for ~$400 parts and labor. They suggested that they do a diagnostic ($65) to make sure of what repairs I need. I looked up the repairs in Alldata and it looks like the intake manifolds are pretty involved compared to the water pump. I called a couple other shops and they said their prices are similar.
    I realize a dealer may charge a higher price for repairs than a "local mechanic" but I don't have a mechanic that I trust, so I am okay paying a little more for that peace of mind, but I don't want to throw my money away.
    My understanding is that if the water pump is leaking my drive belt can get eaten up by the coolant and I need to keep buying coolant to replace the leakage. I believe the intake issue may cause coolant to get into my engine which would be a larger issue, so I'm thinking I should just get both issues take care of.
    My girlfriend's father has a garage and some tools and he said he would be willing to help me with the waterpump, but we looked at a Hanes manual and it looks like you need to remove the power steering pump and I don't know if that is a big deal or not. This is my only car, so if I took him up on his offer, I'd want to make sure we could complete the repair in a single day. I think the intake manifold is beyond the scope of what I am capable of at this point, especially only having the one car in case something takes longer or goes wrong.
    If anyone can offer me any feedback, knowledge or suggestions, that would be great. Even just telling me these issues are typical and just take it to the dealer would be great, I just would like to get any more information before I decide to lay down a thousand dollars or more in repairs.
  2. #2 Re: Intake manifold & Water pump help
    Apr 2009
    stockton ca
    You can do it theres a how to on the lim No special tools needed just the basics and a gasket scraper
    the power steering pump comes off easy as 2 bolts
    im guessing it would take you maybe 8 hours going slow and following the how to on here
    http://www.grandprixforums.net/intake_gasket.php
  3. #3 Re: Intake manifold & Water pump help
    Willoughby, Ohio
    yes follow the write up. replace all gaskets you remove and clean everything. check PCV sytem and replace vaccume hoses while it apart. and GTs just whine, its normal for the L36 to do that i guess thats just how it was made
  4. #4 Re: Intake manifold & Water pump help
    Twin Cities
    So maybe I can do the water pump, but the intake manifold sounds a bit daunting - maybe it's because I don't have the skills and experience the others on this forum seem to have.
  5. #5 Re: Intake manifold & Water pump help
    Willoughby, Ohio
    i think it would cost $500ish if a garage did it. thats enough for anyone to try it!
  6. #6 Re: Intake manifold & Water pump help
    Apr 2009
    stockton ca
    honestly its not thatt bad
  7. #7 Re: Intake manifold & Water pump help
    Willoughby, Ohio
    for a car repair no, but you can save alot by doin it yourself. but if you think about if its the LIM gasket that goes bad, thats $500 over a friggin gasket, but at least the car lasts alot longer so its a good investment
  8. #8 Re: Intake manifold & Water pump help
    Twin Cities
    If I had my own tools and garage and a second car or truck that would be one thing, since I am borrowing someone else's tools and space and they don't live within walking distance, I'm leaning towards doing the water pump myself maybe and having them do the LIM.
    Is there a good way to check to see if the upper, lower or both manifolds are the problem and if the water pump is the problem? The dealer said they will do a diagnostic on it, but I'd feel a lot better if I could know what to look for.
    It was suggested to me to fill the coolant, drive around and then put newspaper down on the ground where I park it and see if I can see leaks from the water pump with the newspaper.
    If you can link pictures that would be most helpful as I'm very limited in car repair skills.
    Thank you.
  9. #9 Re: Intake manifold & Water pump help
    Willoughby, Ohio
    if your gonna replace even one gasket you should just do both just so you wont have to tear it all apart again when the other goes bad.
  10. #10 Re: Intake manifold & Water pump help
    GT Level Member GOINDEF's Avatar
    Holly, MI
    yeah the lim is really not bad, there's just crap in the way, it shouldonly take maybe 2 hours to get the lim off, and thats if you have basic mechanical skills and a how to. just remember what bolts go where on the upper intake manifold, cause a couple of them are length to hole specific i believe
  1. Which intake manifold is better?
    By ya61x in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-12-2010, 11:51 PM
  2. Intake manifold :)
    By TheGreatGatsby in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-03-2009, 05:16 PM
  3. water pump
    By Ramondo411 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2009, 12:35 AM
  4. Water pump ?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 01:21 PM
  5. Intake manifold
    By joesforspeed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 12:15 PM
