Thread: CAI now clicking?
Results 1 to 16 of 16
  1. #1 CAI now clicking?
    Feb 2010
    Ohio, United States
    So I installed a K&N CAI and now I hear a clicking sound when accelerating. The sound is only present under a medium light to medium steady acceleration. When I put the pedal to the floor I don't hear it. The sound is fairly steady, and I would estimate 3-4 clicks per second. Is this normal noise from the engine that I couldn't hear when the factory box was on? My friend has an 04 impala and he has a K&N and it makes the same noise, but it is less pronounced. Thank you for your time and help.
    2006 Grand Prix - K&N CAI with additional insulation added, Dogbone flip, ZZP Shift Kit, Front STB - TOTALED
    2008 Grand Prix GXP - K&N CAI, More to come.
  2. #2 Re: CAI now clicking?
    Lifter tick?
    Sorry you also wasted all that money on a horribly designed intake with TONS of heat soak.
  3. #3 Re: CAI now clicking?
    Feb 2010
    Ohio, United States
    So I looked up lifter tick and I'll check into it. But my car does not make the noise while idling so I'm not sure.
    And I added a lot more insulation to the intake myself, so hopefully that will take care of the heat soak.
  4. #4 Re: CAI now clicking?
    May 2008
    The ticking is probably the metal top/end of the air filter tapping against the PCM or metal body.
    Check the clearance between the filter and the PCM and that the top of the air filter is not close to metal.
    Make sure you used the support bracket that connects to the transmission and underside of the plastic elbow, this will keep it from sagging, which it will over time if the bracet is not used.
    I pushed the filter deeper into the elbow so the top of the air filter is not under the metal, and made sure there is at least 1.5 inches between the PCM and air filter.
  5. #5 Re: CAI now clicking?
    Feb 2010
    Ohio, United States
    Thank you I will check the clearance asap. I did use the bracket that came with it.
  6. #6 Re: CAI now clicking?
    Feb 2010
    Ohio, United States
  7. #7 Re: CAI now clicking?
    Florida
    With it clicking that fast, it might just be your internal noise escaping through your much larger filter. (like how on a s/c car, you get a beautiful whine from the intake when you rev it) And under full throttle it sucking in alot of air so you dont hear the noise. Check your fitment, and if its not that, just listen real close to your filter.
  8. #8 Re: CAI now clicking?
    Nov 2009
    South Boston, MA
    Ihave the same problem with my 05 gp sincce i put the kn. otherwise i love it
  9. #9 Re: CAI now clicking?
    Feb 2010
    Ohio, United States
    I have a friend with an 04 Impala that is doing the same thing (although much less pronounced). I'm guessing it is just internal noise like machinegun said. Thanks for all the advice.
  10. #10 Re: CAI now clicking?
    Florida
    Yeah, its more than likely just internal noise *top end noise really* you're hearing.
    Keep listening, if it starts to sound different, or worse, let us know.
  11. #11 Re: CAI now clicking?
    Nov 2009
    South Boston, MA
    After looking at mine again, i've come to the conclusion that its the butterfly valve in the throttle body slapping around
  12. #12 Re: CAI now clicking?
    Jul 2008
    Tampa, FL
    my 07 with a k&n does the same thing...
  13. #13 Re: CAI now clicking?
    evansville, in
    I upgraded the Mass flow air sensor and my clicking noise stopped.
  14. #14 Re: CAI now clicking?
    Nov 2009
    South Boston, MA
    Quote Originally Posted by blantrip View Post
    Did u notice any mpg differences?, i heard people say they lost economy with the maf.
  15. #15 Re: CAI now clicking?
    upgrading the maf is only necessary (see worth the cost) when you're outflowing your stock one.
  16. #16 Re: CAI now clicking?
    And outflowing the stock one requires TONS of work.
  1. pinging/clicking
    By HELLRAISEHR in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2011, 02:09 PM
  2. 02 auto headlights clicking on/off
    By ececil85 in forum Introductions/Noob Questions
    Last Post: 11-13-2009, 01:35 AM
  3. clicking noise
    By whitegtp in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2009, 05:11 PM
  4. clicking sound under dash
    By CTKGP09 in forum General Tech Discussion
    Last Post: 07-15-2009, 01:04 PM
  5. clicking sound under dash
    Last Post: 06-23-2009, 08:05 PM
