Thread: t.p.s. 06 grand prix
Results 1 to 10 of 10
  1. #1 t.p.s. 06 grand prix
    SE Level Member beast3300's Avatar
    Is the t.p.s. located on the bottom of the gas pedal? And is it a common problem with the drive by wire TB to go bad on these? thanks
    Black 98 Regal GS: best run 13.95@99.75
    99 Red GP L36: 15.5 in 1/4
  2. #2 Re: t.p.s. 06 grand prix
    SE Level Member Stonewall's Avatar
    Rochester, NY
    No it is almost impossible. It is a reduntant system (there are 2 potentiometers working side by side) if one fails the other is used. The TPS is part of the gas peddle. I think it's up on top under the dash next to the fire wall.
    You may have a broken wire or bad connection to the sensor itself.
    Here is the schematic diagram.
    06 GT, HPtuner, PLX Wideband, AFC2.0, K&N CAI, PEM/PLOG 3"DP, ZZP 3.5MPS, CORSA CATBACK, GMPP STB's, GMPP HD Tarms
  3. #3 Re: t.p.s. 06 grand prix
    wow! thank you for the quick response. What would you think would be at fault if a t.p.s. code is present. Now the car runs perfect and light is back off, but when it was messing up the car had no acceleration or power. The pedal sensor or the big bulky TB.
  4. #4 Re: t.p.s. 06 grand prix
    Rochester, NY
    Do you know what the actual code was? That would be a big help in narrowing it down.
  5. #5 Re: t.p.s. 06 grand prix
    Quote Originally Posted by Stonewall View Post
    The code is P0068 then it says see service manual. I asked my friend at a repair shop that brought it up on his mitchell said it is tps sensor.
  6. #6 Re: t.p.s. 06 grand prix
    Rochester, NY
    OK that helps.
    That code will get set when the PCM sees a condition where it compares engine load and air flow through the intake with the expected throttle position. If the throttle position is not where the PCM expects it to be then it will reduce engine power and put up that code.
    My bet is you had a problem with to much airflow or a leaking vaccum line.
    Check the following:
    The vacuum hoses for splits, kinks, and improper connections as shown on the Vehicle Emission Control Information label--Inspect thoroughly for any type of leak or restriction.
    Air leaks at the throttle body mounting area and the intake manifold sealing surfaces
    Restrictions in the Air Intake System, including the filter.
    Check the throttle body as well:
    Loose or damaged throttle blade
    Broken throttle shaft
    Damaged throttle body
    I doubt very much that it's the TPS. It's one of the things above that caused the code. As long as it isn't showing up your OK but it never hurts to go through and check it out.
    Hope you find the problem.
  7. #7 Re: t.p.s. 06 grand prix
    thank you very much for you help, tomorrow I will look into it some more. You guys are great on this forum!
  8. #8 Re: t.p.s. 06 grand prix
    Hoffman/Schaumburg, IL
    I'd say start small, It sounds like a dirty air filter could cause this code (reduced air flow)... then work towards the harder stuff
  9. #9 Re: t.p.s. 06 grand prix
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    ...need to check out MAP/MAF sensors also-- see official troubleshooting info --
    t.p.s. 06 grand prix Attached Images
  10. #10 Re: t.p.s. 06 grand prix
    GT Level Member njbrain's Avatar
    Rhinelander WI
    Like was said earlier, there are two APS's (Accelerator position sensor) on the car for safety reasons. When one fails, the car will go into "limp" mode so you will know that there is a problem. Whether it is a sensor, wire, or module, only a proper diagnosis will tell. If I remember correctly, you have to have a fault with the APS circuit to set the APS code, so I don't think that an air filter would cause the problem. However, a dirty, sticking throttle plate could. In reality, if the air filter was that dirty, you will have a serious fuel trim issue.
  1. my grand prix
    By grandprix0429 in forum Off Topic Discussion
    Last Post: 06-22-2010, 08:07 AM
  2. New to Grand Prix
    By POLECAT2007 in forum Introductions/Noob Questions
    Last Post: 02-23-2008, 01:05 PM
  3. Want a Grand Prix for under 5,000....
    By redsrule2500 in forum Off Topic Discussion
    Last Post: 02-16-2008, 12:57 PM
  4. New to me Grand Prix GT 97
    By mainecrab in forum Visual/Body Modifications
    Last Post: 02-10-2008, 11:38 PM
