Thread: l36 mods want to get into the 14s
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 l36 mods want to get into the 14s
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    hi i own a 2001 gp gt my mods are zzp plog 2.5 catted dp hv3 insert 180 degree t stat zzp shift kit and a cone filter oh and i have mufflers removed with cherry bombs on the back god i hate the drone right now i run a 15.4 1/4 mile but i want to break into the 14s i have a l67 tb and injectors at home here and i am planning on getting a overkill pcm how much gain will that get me and will it get me to 14s if not what will 1.9 roller rockers get me into thanks
  2. #2 Re: l36 mods want to get into the 14s
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Top Swap!
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  3. #3 Re: l36 mods want to get into the 14s
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    if you insist on staying n/a, cam!
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  4. #4 Re: l36 mods want to get into the 14s
    Put the GTP injectors and TB on it and have it tuned...and get rid of that craptastic 2.5" DP...and go 3" or nothing. Mufflers...I've got stock ones here if you want them.
    IMO, I'd get the tune...see how much difference that makes...then, get the rockers.
    See how far that gets you...you might try flipping the stock mounts for less movement and a better launch...what are your 60 ft. times? You can also just have your stock L36 TB ported from Reptile too. Just a thought.
  5. #5 Re: l36 mods want to get into the 14s
    ya i can't afford the top swap i really want it but the shipping cost alot to canada so wht i wanted to know is if i could use a l67 tb injectors and some rockers and overkill pcm to get mid to low 14s i am happy as long as i can beat all the ricer with there turbo civics and som mustangs with boltons most the car at the track i race run hight 13s to high 14s but of course you have stock civics at like 16-17 and you get done out v8s and swaped vehicles running 8-12 just want to run where the majority is im really close almost beat a fox body mustang he got like 14.9 i was 15.4 my car just has nothing after half track.
  6. #6 Re: l36 mods want to get into the 14s
    im averaging around 2.3-2.4 but on my best run i did
    r/t .275
    60' 2.198
    330 6.409
    1/8 9.933
    mph 69.28
    1000 12.933
    1/4 15.471
    mph 88.18
    i notice to that if i run 87 octane i run 15.8 but if i put in 94 i brings me to 15.4-15.5
    p.s we run a pro tree 3 amber flash then green
  7. #7 Re: l36 mods want to get into the 14s
  8. #8 Re: l36 mods want to get into the 14s
    a better 60' would put you into the 14s.
    thanks bio ya im running a set of used street tires on a set of steel rims i got from the wrecker id like to get some drag radials or even snow tires if i cant afford drag radials wht do you think how can i inprove my 60 ft thanks again
  9. #9 Re: l36 mods want to get into the 14s
    Agreed.
    Get a 2.1 or 2.2 60 foot and there's your 14's. No other mods required...but I would flip yourstock mounts to get the motor stiffer for les movement/transfer. Also lower your tire pressure...start at about 26 psi and go down from there.
  10. #10 Re: l36 mods want to get into the 14s
    however, if you want to eek a little more power out of it i would swap out your 2.5" downpipe for a 3" version and then buy some modded 1.9:1 rockers. then you will for sure be able to break into the 14s so long as you can launch the car well.
  11. #11 Re: l36 mods want to get into the 14s
    IMO...^^that...should be good for a 14.8-14.6 area with a GOOD launch.
  12. #12 Re: l36 mods want to get into the 14s
    thanks for the replys guys i think wht i will do is install the injectors tb and get a pcm tune lower tire pressure and the mounts see where i am then get the 1.9 yella terra rockers any suggestions on valve springs and i have one more Q for the mounts all you do is flip the dog bones thanks again
  13. #13 Re: l36 mods want to get into the 14s
    You flip the black, rubber mount in the front from sitting vertical...to sitting horizontal. You turn it 90*
    Check it out in my thread Safely Modding Your 3800 in the general tech section...IMO...I'd try to go back and just try to lower your 60 foot time.
  14. #14 Re: l36 mods want to get into the 14s
    thanks for the in put ill do that but im still gunna get the pcm cuz mine is stock and i alread have the injectors and tb sitting in the closet got them for 40 buck for all.
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  15. #15 Re: l36 mods want to get into the 14s
    Getting some factory aluminum wheels might help a little actually.
    Steelies are heavy as ****.
  16. #16 Re: l36 mods want to get into the 14s
    hey matt where in canada are you im in bc
    sold 97 GTP stock
  17. #17 Re: l36 mods want to get into the 14s
    ontario
  18. #18 Re: l36 mods want to get into the 14s
    ontario
    too bad do you know if there are any clubs or any one who can tune out west here
    sold 97 GTP stock
  19. #19 Re: l36 mods want to get into the 14s
    Get an Overkill PCM then...Will is in Canada.
  20. #20 Re: l36 mods want to get into the 14s
    swift current,sask.
    Quote Originally Posted by nascartech View Post
    Hey take a look at the WCGPC forum, I know there are a few guys out in that neck of the woods.
  1. 3.4 mods
    By N8Dogg98 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 07-22-2010, 09:34 PM
  2. Mods
    By toby in forum General Tech Discussion
    Last Post: 11-05-2009, 11:10 PM
  3. 18's with no mods
    By hacket in forum Tires & Wheels
    Last Post: 03-18-2009, 10:14 AM
  4. Next Mods
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2009, 02:11 AM
  5. New Mods?
    By gucci in forum General Tech Discussion
    Last Post: 01-10-2009, 07:55 PM
