Thread: fuel rails and Intercooler kits
Results 1 to 20 of 28
  1. #1 fuel rails and Intercooler kits
    GT Level Member GOINDEF's Avatar
    Holly, MI
    I'm looking into doing a top swap, but I was wondering is there any way to use the factory L67 fuel rail after I put the ZZP stage 3 intercooler kit in, or do i just have to buy a new fuel rail
  2. #2 Re: fuel rails and Intercooler kits
    Banned - Busted For Scamming
    Feb 2009
    You could mod the stockers, not my preference. Just make your own fuel rails. lol
  3. #3 Re: fuel rails and Intercooler kits
    get a stage 2 intercooler. it wont **** up like the stage 3 will.
  4. #4 Re: fuel rails and Intercooler kits
    Holly, MI
    how does the stage 3 mess up?? its suppose to keep everything cooler
  5. #5 Re: fuel rails and Intercooler kits
    Feb 2009
    it doesnt. Bio is drunk
  6. #6 Re: fuel rails and Intercooler kits
    Just get the stage 2...and fuel LOGS.
  7. #7 Re: fuel rails and Intercooler kits
    Jan 1970
    Maquoketa, Iowa
    I think a buddy has a modified fuel rail for sale still, lmk if interested.
  8. #8 Re: fuel rails and Intercooler kits
    Holly, MI
    I'm interested FOSHO, let me know if he's got pics and what he's askin.
    so then the stage 3 is a good intercooler kit, or I should go with stage 2?
  9. #9 Re: fuel rails and Intercooler kits
    the stage 3 wont do much more than a stage 2 will and it costs that much more for that bogus layer "to keep heat soak down". you cant run an EGR with it either or youll screw up the core. i would never get a stage 3 when a stage 2 is available.
  10. #10 Re: fuel rails and Intercooler kits
    You can get injector spacers.
    I've seen 3 of 3 ZZP modded rails leak. Personally, it's the PRJ logs for me.
  11. #11 Re: fuel rails and Intercooler kits
    ^^Agree.
  12. #12 Re: fuel rails and Intercooler kits
    Jersey
    PRJ rails are tits.
    16' wrx sti- stock
  13. #13 Re: fuel rails and Intercooler kits
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by GOINDEF View Post
    He sold them already, sorry.
    Quote Originally Posted by 99prixgt View Post
    PRJ rails are tits.
    Also are a $500 cosmetic upgrade though. Stock fuel rails have been pushed to 600whp with an upgraded pump.
  14. #14 Re: fuel rails and Intercooler kits
    Holly, MI
    so you guys really think that the heat soak isnt an issue and that the stage 3 is junk?
    I dont really have a choice with the fuel rails, zzp has the cheapest ones, next to wbodystore
  15. #15 Re: fuel rails and Intercooler kits
    yes, heat soak is not an issue unless you like to do long WOT runs on the highway. even if you hot lap at the track its probably still going to work well enough. dont pay the extra money for the stage 3.
  16. #16 Re: fuel rails and Intercooler kits
    Holly, MI
    well that sort of is me, but I would still think no matter what that stage 3 would be better, I mean its the same principle as the throttle body spacer, it keeps the TB alot cooler.
    what about getting the stage 2 kit and then the 1/4 supercharger spacer? the only thing I'm not sure about is the height, cause that would add 2.5 inches, and I dont know if that would stay under a stock hood.
  17. #17 Re: fuel rails and Intercooler kits
    Feb 2009
    Conduction isnt the only thing at work causing that core to heat soak. Convection is another issue, the surrounding engine temperature causes the aluminum to suck up all the heat around the core. Phenolic is an insulator and would help a ton.
  18. #18 Re: fuel rails and Intercooler kits
    Jan 1970
    Maquoketa, Iowa
    I don't see the issue with phenolic. The alum. cores work well when the pump is running, but after you turn the car off, you will notice the supercharger soaks up the heat after it sits. So at the track you would want to keep it running in the pits. With the phenolic, this is not really an issue.
    You would not want another spacer on top of a stg 2 core, too many potential leaks, custom s/c bolts would be needed, etc.
  19. #19 Re: fuel rails and Intercooler kits
    why not just run a bigger cam and NOT an intercooler? what is everyone's love for intercoolers? i get that its probably the most cost effective mod, but a cam setup by itself can usually run as fast as people want to go with the car. you can run 12s cam only.
  20. #20 Re: fuel rails and Intercooler kits
    Well how do you change the cam on these cars...
  1. nitrous intercooler kits...
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2009, 01:33 PM
  2. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
