Thread: engine hesitating
Results 1 to 17 of 17
  1. #1 engine hesitating
    Nov 2009
    canada
    Hello all i am new to the site seen lots of good info here but still can't fix my problem.I have 2001 grand prix gt. engine hesitates when i leave from a stop and once i get up to my speed and foot is just resting on the gas engine starts hesitating again i changed plugs whires air filter fuel filter cleaned MAF I am running out of things to check can anyone please help.I am aslo getting about 300km per full tank of fuel.Not good.no service engine light
  2. #2 Re: engine hesitating
    Apr 2009
    stockton ca
    cats could be causing some of these problems but generally they would cause power loss more then what you described
  3. #3 Re: engine hesitating
    Nov 2009
    canada
    The power is there when I need it. Hesitation is only at low rpm and if i bring up rpm in park it is fine but if i put it in drive hold brake and raise rpm to 1500-2000 engine starts to hesitate.
  4. #4 Re: engine hesitating
    Colorado
    I am having the exact same problem with my 2000 Grand Prix GT. I've done the same, replaced the plugs, wires, and fuel filter. I've also had the fuel system cleaned as well as fan fuel injector cleaner through the gas tank before and after the cleaning.
    Could this be a problem with the fuel pump itself? From what I've read, it doesn't sound like a fuel pump problem would cause these symptoms, but like you, I've run out of things to check. What about the ECU "electrical control unit" or a sensor (throttle position sensor or O2 sensor)?
    I only have 100,000 miles on it and would love to keep it another 3-4 years.
    Any suggestions??
  5. #5 Re: engine hesitating
    Nov 2009
    Grand haven
    I woluld look at your MAF sensor and your cat to make sure its not pluged.
  6. #6 Re: engine hesitating
    GTX Level Member cerick08GP's Avatar
    Well, I can’t say for sure what your problem is. But this is what I would do. #1 Take your car out for a drive tonight, get on it a little bit. Then stop in a dark area, and pop the hood with the engine running. Look at your exhaust down pipe before the catalytic converter. If it is glowing red, your catalytic converter is shot. #2 Replace your front O2 sensor, even if it is not the problem replacing it will give you better mpg. They only last about 100k-120k, and they can malfunction for a long time without throwing a code. On a side note of information, all O2 sensors fail over time. They constantly degrade when exposed to the atmosphere, even if your car isn’t running. I worked for years with confined space atmosphere testers, the O2 sensors never lasted more than about two years max. So believe it or not, a car O2 sensors lasting about 8 years is pretty amazing IMHO. #3 Check for vacuum leaks.
    Good luck.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  7. #7 Re: engine hesitating
    New Jersey
    Most guys here know far more about these cars then me, My learning pretty much ends at the late 80s, however.
    EGR valves can often cause bad hesitations if they are hanging up and leaking OR if the wrong valve was installed.
  8. #8 Re: engine hesitating
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I had almost the exact some problem. Cleaning the MAF sensor didn't fix it. Replacing it did, however.
  9. #9 Re: engine hesitating
    Nov 2009
    canada
    Mr Tube you got it that was my problem it took like 3 months for a ses light to tell me the problem was a bad egr valve. New egr was like $300 bucks yeah crazy and gasket $20 also crazy so i went the cheap way i bought a used egr from scrap yard for $20 and a new gasket $3 from uap.
  10. #10 Re: engine hesitating
    Nov 2009
    Overland Park, KS
    You can go buy two cans of SEAFOAM, they sell it at advance auto/auto-zone.. Put one in ur gas tank when the gas level is at the last notch b4 empty. Take the other can and remove ur vacume hose from ur brake booster while the car is running. (REMEMBER DON'T NOT HIT UR BRAKES CAUSE YOU WILL OUT AIR IN UR BRAKE SYSTEM) Feed the sea-foam through the hose until the can is empty. The car will cut off. When that happens take off the hose that leads to the throttle intake and take the throttle of cleaning it with fuel injection throttle cleaner. I recommend 4 cans. 2 to clean the throttle and the other for the intake. You will see black stuff come out as you clean the intake. Once you clean the throttle and intake put everything back together. Now when you will have to done that 15mins should have went by. When you crank the car up will see a lot of white smoke when you rev the engine. That all the carbon built up in ur engine. the sea-foam you put in ur gas tank will remove bad gas and water out of ur lines and tank. Its best to run ur car on the highway or a long street. this should get rid of the hesitation.
  11. #11 Re: engine hesitating
    New Jersey
    I doubt that will do anything to the EGR valve or passages.
  12. #12 Re: engine hesitating
    Nov 2009
    Overland Park, KS
    Quote Originally Posted by cerick08GP View Post
    Good luck.
  13. #13 Re: engine hesitating
    SE Level Member Alucarus99gt's Avatar
    St.Paul, MN
    hahaha.... Ne who... Ya I would say the egr. I don't know what it is with 3800's and the egr, but they have a weird relationship. I was driving next to my friend on the highway not that long ago and I was like fxxk it and I gunned it. Haha. When I got to a stop light it was idling really eratically and I stopped at a parking lot to check it out, but it already smoothed out. I think it was just a piece of carbon that got stuck in the egr. I talked to another kid with a bonneville ssei and his was doing the same thing as yours and my best guess would be the egr. Its pretty common. Nothing stays clean forever.
  14. #14 Re: engine hesitating
    GT Level Member clevelandfan's Avatar
    ohio
    Quote Originally Posted by devante46 View Post
    a couple things here. one, you dont need that much seafoam to do it. one for the gas, 3/4 for the vacuum line, and a quarter for your oil. your not even supposed to do that much, but it wont hurt. and as for the shutting off part. just have someone raise the idle when your putting it in, and it wont even do that. and yes, run it on a long street. and be ready for a lot of smoke. i had a guy do this at advance a week ago, and it smoked so bad the cops called lol.
    ps, if u wait till april seafoam is goin on sale at advance auto for 6.99! cheapest ive seen it in a long time
    97' Grand Prix. Blurring the lines between SE, and GT
  15. #15 Re: engine hesitating
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    you have a bad cat, pull the o2 in the rear exhaust manifold and take it for a ride with it out, if u have all power back u need a cat simple as that dont replace parts when u dont haft to
  16. #16 Re: engine hesitating
    New Jersey
    did everyone miss where he said he solved the problem on 1/25/10, it was EGR?
  17. #17 Re: engine hesitating
    Feb 2010
    ohio
    Quote Originally Posted by MrTube View Post
    lol we dont check dates around here. i see sum1else brought this thread back from the dead and it didnt help i didnt read tha date WHOOPS
  1. Engine hesitating while driving
    By forgerat1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-23-2010, 11:17 AM
  2. hesitating shifts
    By kinglou10 in forum General Tech Discussion
    Last Post: 06-26-2009, 01:21 PM
  3. misfiring?, hesitating? valve lash?
    By icolex1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-26-2009, 08:03 AM
  4. Hesitating shifts
    By Andrew_99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2008, 01:03 PM
