Thread: 2 questions
Results 1 to 5 of 5
  1. #1 2 questions
    Feb 2009
    staven
    (1) How hard is it to replace the crank sensor?
    (2) Does anyone have a diagram of the hoses that run off the fuel tank.
    Thanks
  2. #2 Re: 2 questions
    Feb 2008
    1) Remove belt, jack up car, remove wheel, remove splash guard, remove crank bolt, use harmonic balancer puller to remove crank, unplug and unbolt sensor. Opposite for re-installation. (~2-hour job the first time around. Then, it get much easier and quicker.)
    2) No diagrams, but what do you need to know about them?
  3. #3 Re: 2 questions
    Feb 2009
    staven
    I put a fuel pump in my 97 gp and I broke one of the plastic lins so I got them from the dealership. installed the pump and lines but when I got to the end of the job I have an extra one not pluged in to anything and can't find any other one to hook it to. It lays and follows the tank like it would go towards the fuel filter. and now I have a P0440 code. The only thing I come up with so far is maybe they gave he the wrong lines.
    btw my ck engine light wasn't on till I did a fuel pump. I had to plug the line due to if I fill the tank up with gas it would pour out of that line and make a mess on the ground
  4. #4 Re: 2 questions
    there are two lines for a reason. you have a fuel system that constantly circulates and returns fuel to the tank after it goes through the fuel rails.
  5. #5 Re: 2 questions
    Wausau, WI
    yes sir, you are correct.
  1. HV3 questions...
    By whitelightnin04MC in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-23-2010, 11:43 PM
  2. Looking for a new GTP and have a few questions
    By nawarkk in forum General Tech Discussion
    Last Post: 09-18-2009, 01:05 PM
  3. Car questions
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 07-18-2009, 12:01 AM
  4. I have few questions...
    By DDPeppa in forum Visual/Body Modifications
    Last Post: 05-31-2009, 02:41 AM
  5. IPW questions
    By fst in forum PCM Tuning
    Last Post: 01-11-2008, 06:44 AM
