Thread: top swap
Results 1 to 3 of 3
  1. #1 top swap
    SE Level Member Grandprixboy1224's Avatar
    Lapeer
    so has anyone done a top swap to a n/a 3800? im thinking about doing that to my gt.so i got a few question for the ppl that have done it .
    1. how long did it take?
    2. how much did u spend on the top swap?
    2000GP-GT|CC|8%tint|Exhaust DRT|CAI| Ordering KV5 and 10000k HID.
  2. #2 Re: top swap
    took me a week because i didnt have some parts that i needed, otherwise it would have taken me the weekend.
    i spent around $1000 on doing it all. but honestly, if youre really interested in doing this and you dont have a lot of experience with it you might want to consider building an engine on the side with some supervision and then dropping it in the car. pulling the heads while in the engine bay can be done, as ive done it a few times, but its WAY easier on an engine stand or a work bench.
    overall there are a lot of things do do for the swap. the added compression from the l36 block makes it more finicky when running boost, you cant run as much. youre almost best off doing a complete l67 swap.
    coming from someone who has done this, blew up the motor, and then done an l67 swap...do the l67 swap. ive gone through a block and a set of heads from not putting the engine together the right way. there is a lot of little crap that you need to make sure is done, otherwise your setup is DOA.
  3. #3 Re: top swap
    SE Level Member 1998gpgt's Avatar
    McHenry, IL
    I have the ZZP SS M90 kit https://www.zzperformance.com/grand_...=382&catid=109 and I spent about $900 on mine. But i also got around some of the costs by using custom fabricated L67 rails and using a die grinder on the supercharger casing to clearance the injectors. With all the neccessary parts from ZZP, it would be somewhere around $1500. One of my buddies, who is a mechanic, helped me out with the install and I think the total install time was about 5 hours.
    1998 Grand Prix GT 337whp/363wtq 12.952 @ 112.02
    2000 Grand Prix GT & 2007 Grand Prix GT
    2004 GTO 13.610 @ 102.69
    1985 Cutlass 455/TH350
  1. DIC swap
    By chrissbee77 in forum General Tech Discussion
    Last Post: 12-13-2008, 04:29 PM
  2. DIC swap
    Last Post: 02-26-2008, 06:02 PM
  3. Need For Gen V swap ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2008, 04:20 AM
  4. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
  5. 97.5 pcm to 98 swap?
    By monte0 in forum PCM Tuning
    Last Post: 01-07-2008, 10:09 AM
