Thread: thinking about buying a 98 with a bad motor
Results 1 to 5 of 5
  1. #1 thinking about buying a 98 with a bad motor
    SE Level Member allensteiner21's Avatar
    could use some advice from you guys - i have a chance to pick up a black gt for around $400 and in great shape. the prob is that one of the valves broke off and seized the motor - that's what the owner told me.
    what can i expect? replace the whole engine or might i get lucky and need only a new head? i want the car regardless...just a question of convincing the old lady.
  2. #2 Re: thinking about buying a 98 with a bad motor
    canada
    well, only way to tell is taking it apart and going form there. how many miles on the thing? If it is high mileage might consider getting a used one iwth low miles and rebuild that one and have a fresh low mileage motor.
  3. #3 Re: thinking about buying a 98 with a bad motor
    the engine has around 151k miles. i hear that's quite a bit for a domestic but i want it as a project anyways...i guess i'll find out how bad it is
    how much of damage can a loose valve cause? any more than some scratching?
  4. #4 Re: thinking about buying a 98 with a bad motor
    151k is not a lot for a 3800. in fact, it happens all the time. if he really dropped a valve there is piston and cylinder damage so youll either need a rebuild or a new motor. i would suggest a new motor just for your ease.
  5. #5 Re: thinking about buying a 98 with a bad motor
    I'd do it and drop a used motor in. Figure at the most the motor costs you around $500 and you have a good car that's worth more.
  1. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
  2. thinking of buying these rims what do you guys thing
    By GrandPrixGT00 in forum Tires & Wheels
    Last Post: 07-05-2009, 08:24 PM
  3. Thinking about buying a '97 GT, but....
    By jasond in forum General Tech Discussion
    Last Post: 07-01-2009, 05:31 PM
  4. Thinking about buying 07 or 08 GP
    By sn95gt50 in forum Audio, Security & Visual Electronics
    Last Post: 04-13-2009, 08:08 PM
  5. Buying a GTP
    By Rod in forum Introductions/Noob Questions
    Last Post: 06-21-2008, 09:43 PM
