Thread: Engine surges and cuts out
Results 1 to 6 of 6
  1. #1 Engine surges and cuts out
    SE Level Member timmyg's Avatar
    minnesota
    '99 Grand Prix GT - Dealer did recall - They needed to move some wires. Couple weeks after that problem started. Started out like the tranny was slipping then it started to surge when at idle. Then idle and while driving. Now, still suges during both plus if I push gas normal engine cuts out, release gas comes back, might even stall. I have to feather the peddel to move. Code: P0102 MSA & MAP. Replaced both worked fine for 2-3 weeks. Problem returned worst than before. Rechecked MAS and MAP all good. EGR replaced with in the last year also replaced idle sensor and air filter. I have the TPS but thats not the problem. Had dealer put it on Tech II and they said it was the MAS or MAP. I'm running out of ideas. Help!!!
  2. #2 Re: Engine surges and cuts out
    MAS? You mean Mass Air Flow sensor right? If the MAF is the issue, unplug it and try driving that way. The first couple starts may be tough as the pcm learns and adjusts off the tables instead of real time data.
    BTw, here's the FSM write up for P0102 http://gearchatter.com/viewtopic1176...b2c3086116db21
  3. #3 Re: Engine surges and cuts out
    minnesota
    The MAF, MAP and Idle control sensor are new. I unpluged the MAF the first time and it did stable out but now I can unplug the MAF, MAP, TPS and Idle control with no effect. Still surges and blows P0102. When I installed the MAF and MAP the car ran OK for 2 or so weeks. But we noticed the MPG started to slowly go down. Also, I forgot to mention that the Track control went to "Track Off" and I am unable to turn it back on.
  4. #4 Re: Engine surges and cuts out
    Canada
    I just had this problem and it ended up being my fuel pump....
  5. #5 Re: Engine surges and cuts out
    SE Level Member pontiac's Avatar
    Nova Scotia, Canada
    Could a problem like this be caused by bad gas? Because I just got gas today and my car (02 GT) developed the exact same symptoms and after probably 20km of driving just quit going up a big hill about 1km from my house. I did however get it restarted and made it home.
  6. #6 Re: Engine surges and cuts out
    missouri
    Quote Originally Posted by 1000PRIX View Post
    did you have the same problem or the same problem and the same code P0102?
  1. Installed Locx (rca converter) and now sub cuts out
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 11-05-2010, 11:25 AM
  2. @115 Engine Cuts out
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 08-23-2008, 09:51 AM
  3. Car runs rich and surges at an idle?
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2008, 02:54 PM
