Thread: Sluggish crank
Results 1 to 9 of 9
  1. #1 Sluggish crank
    SE Level Member Fubisin's Avatar
    London, ON
    I have a problem!
    I have noticed that sometimes, not always when I go to start my 04 GT, it fires but doesnt seem to fully fire and sometimes fires but then "boggs" out and doesnt start. Its hard to describe but it will turn over but instead of a total rev it is a rev then a drop then either the bog to not started or a rev to a drop then a sluggish idle.
    ANY IDEAS!
    I just called the garage but I havent talked to my guy yet.
    I was thinking running the tank somewhat dry, replacing the fuel filter, fuel lines and 3 step de-carbing my system.
    Its pissing me off because when I go to show someone, it fires no problem
    HELP PLEASE
  2. #2 Re: Sluggish crank
    London, ON
    PROBLEM SOLVED a while back, just a update.
    I took it into the one of the GM dealers up here and they called it a "hot start"
    Didnt give me much details except that it was a simple computer update and a throttle body clean. Did it, now it runs great, except I have noticed it doesnt have the same balls it used to??..??
  3. #3 Re: Sluggish crank
    GTX Level Member cerick08GP's Avatar
    I have never heard of that before, nice information to know incase it happens to me.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: Sluggish crank
    Cleaning the throttle body every 10K or so does wonders for those drive by wire cars...I say if you change your oil every 3K clean the throttle body once every 3 or 4 oil changes...I just did it on my '07 Cobalt with 35K and it was NASTY
  5. #5 Re: Sluggish crank
    How many miles are on your car? It is just a few bolts it probably wouldn't hurt...
  6. #6 Re: Sluggish crank
    London, ON
    Blue,
    85000 Miles or 135000 KM's
  7. #7 Re: Sluggish crank
    Meh...I'd do it...this was directed towards cerick too...
  8. #8 Re: Sluggish crank
    London, ON
    well, I guess I beat him to the punch.
  9. #9 Re: Sluggish crank
    Wausau, WI
    so.........problem solved?
  1. No Crank - No Start!!
    By coolken84 in forum General Tech Discussion
    Last Post: 03-05-2009, 10:15 AM
  2. HELP! Cranks then Don't Crank
    By Bigboy49251 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2009, 03:25 PM
  3. sluggish
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-07-2009, 11:44 PM
  4. Sluggish after coil pack install
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-14-2008, 05:31 PM
