Thread: does anyone know how to fix this code?
Results 1 to 15 of 15
  1. #1 does anyone know how to fix this code?
    nwa
    i have a 97 grandprix gt with the 3.8 v6 and its throwing the 102 low curcit mass airflow sensor code being thrown. ive changed the MAF once already and its brand new. just changed the idle air control valve and ive changed the tps after consecutive failure.. does anyone have and idea why the low curcit code for the MAF is still being thrown? anything will help thanks! Tim
  2. #2 Re: does anyone know how to fix this code?
    Charles City, IA
    check the fuse in the under hood fuse block. it is like a 5 amp i think can't remember for sure tho.
    SMGPFC Two Nipple General
  3. #3 Re: does anyone know how to fix this code?
    Wausau, WI
    how is the wiring connecting to the MAF sensor? Is it cracked or seperated anyhwere.........shorting or open circuit?
  4. #4 Re: does anyone know how to fix this code?
    nwa
    Quote Originally Posted by Liquifire View Post
    i didnt see any cracks or anything at all and i didnt see a fuse labled for it but i check most every one of them and i didnt see any that were blown
  5. #5 Re: does anyone know how to fix this code?
    SE Level Member KlutchKrunch's Avatar
    Canada
    Take your sensor out, and take off the intake pipe, get some throttle body cleaner(Intake Medic by Gunk works) and clean out your Throttle body. Failing that, check to see if the sensor that's on the intake pipe is actually properly connected. Also, check for any vacuum leaks, these leaks could be at the intake manifold, throttle body or EGR Valve flanges. And, even for a laugh, check your PCV Valve.
  6. #6 Re: does anyone know how to fix this code?
    nwa
    this problem ended up being a fuse under the drivers seat.. strang?
  7. #7 Re: does anyone know how to fix this code?
    What fuse under the drivers seat?
  8. #8 Re: does anyone know how to fix this code?
    nwa
    Not for sure my mechinic just said it was one of them
  9. #9 Re: does anyone know how to fix this code?
    GT Level Member neel2008's Avatar
    Huntington, IN
    fuse under the drivers seat? huh? lol
    97gtp
  10. #10 Re: does anyone know how to fix this code?
    Akron Ohio
    What??? How much did you pay him?
  11. #11 Re: does anyone know how to fix this code?
    I think we can say it must have been under drivers ....wait.. you don't have fuses under the drivers dash etiher...
    Odd.
  12. #12 Re: does anyone know how to fix this code?
    SE Level Member awesomefullness's Avatar
    Red Deer Canada
    check all the wires to the maf sensor harness. Check and clean all your engine grounds as well.
    Good luck
  13. #13 Re: does anyone know how to fix this code?
    GT Level Member donmega's Avatar
    St louis, mo
    that sucks you replaced all those parts. FLOW CHART FLOW CHART FLOW CHART. check fuses first.....My teachers would get sooooo pissed about that.
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  14. #14 Re: does anyone know how to fix this code?
    Jul 2008
    sumter,south carolina
    u got jacked homie.. i had a serious vac leak causing all teh probs u stated.. dude prob just fixed a vac leak and robbed u for what he could.
    02 GTP with mods 05 GP for DD
  15. #15 Re: does anyone know how to fix this code?
    St louis, mo
    fuse under the seat does sound suspect. I wouldve asked him what fuse....
  1. I got a code!!!???
    By justwhisen in forum General Tech Discussion
    Last Post: 04-14-2010, 07:22 PM
  2. Need help! p0141 code.
    By rcweldon988 in forum General Tech Discussion
    Last Post: 03-05-2009, 10:22 PM
  3. engine code
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-15-2009, 04:42 PM
  4. PCM code clearing
    By spinhunt in forum General Tech Discussion
    Last Post: 02-07-2009, 09:51 PM
  5. code...
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2009, 12:22 AM
