Thread: SLP Headers
Results 1 to 20 of 20
  1. #1 SLP Headers
    GT Level Member GP2003GT's Avatar
    Fayetteville, NY
    hey, how is everyone? welli just wanted to see what others think about the SLP headers whether you have them or you dont, because i am thinking about getting them and taking out my ported ceramic coated manifolds...of course this is going to be after i get the HV3, ported HVTB and ER rockers
    http://www.cardomain.com/ride/2556536 NKG Iridium Plugs, 8mm Spiro Wires, ZZP Reprogrammed PCM, ZZP 3" full cat, ZZP Ceramic Coated Ported Manifolds, ZZP HV3, ZZP HVTB, ZZP ER Ratio Rocker Arms, ZZP Drilled 180* Thermostat, MotorSports Performance Intake, Reptile's IAT and dezldave tuned
  2. #2 Re: SLP Headers
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    I favor SLP headers over any other brand for a number of reasons and have since they first came out. There were a few problems out of the first batch or two that shipped out but they have been resolved since. Just beware that adding headers to a NA car may cause you to notice a bit of low end torque loss during daily driving at lower throttle positions. The rear header can be a chore to install as the downpipe is integral with it. The quality is top notch and very high quality. Just make sure you get the install kit as it includes gasktes, 02 wire extension, clamps and a few bolts.
  3. #3 Re: SLP Headers
    Fayetteville, NY
    ok i see...
  4. #4 Re: SLP Headers
    GT Level Member Preotic's Avatar
    Missoula, MT
    Make sure to replace the flex it comes with, it likes to tick and annoy the hell out of you. If you put the rear header on with the original flex and it ticks you'll most likely not want to uninstall and reinstall the rear header ever again. Other than that my slps have neve leaked and i installed them back in the day before i knew what KR was and all the other essentials.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  5. #5 Re: SLP Headers
    Fayetteville, NY
    yeah im not sure if i want to do it now...lol, i just like how they look better...i also def dont want to lose low end...
  6. #6 Re: SLP Headers
    Missoula, MT
    If you did someday do a topswap, then headers would be a very good mod.
  7. #7 Re: SLP Headers
    Elk Grove Village, IL
    I had SLPs on my GT with ER rockers and other mods. It was alot of fun. Had the HVII on as well and the car was a highway screamer. Low end lacked with the HVII and headers. A stall and gears would have taken care of that problem though.
  8. #8 Re: SLP Headers
    Fayetteville, NY
    hmmm decisions, decisions how much would a top swap run me?
  9. #9 Re: SLP Headers
    Banned
    New Port Richey Florida
    Hmm about a grand to 1,500 depending on the condiiton of the parts. But i've seen and from talking to other gtp owners that pace setters are the way to go or togs. But make sure you re use the stock gaskets or get new stock gaskets.
  10. #10 Re: SLP Headers
    Bastard Reptile's Avatar
    Kansas City, MO
    There is no point in re-using gaskets. They're what....6 bucks...not worth the PITA only to have a leak at the end of the day.
    Cost effectiveness, pacesetters are a good compromise....IF you know what you need ahead of time.
    TOG's and SLP's are still the cats meow in the header world, but they're $$$$$$$
  11. #11 Re: SLP Headers
    Banned
    True but the pace setters have a problem with a clamp that keeps comming loose a kid i know local to me had a set and had that happen 3 times
  12. #12 Re: SLP Headers
    Oklahoma
    The saying "You get what you pay for" is coming to mind.
  13. #13 Re: SLP Headers
    Banned
    Thats true but when people are on a budget what can ya do. They gotta get what they can afford.
  14. #14 Re: SLP Headers
    Oklahoma
    Quote Originally Posted by 19SE92 View Post
    Very true and I wont argue that point. But also to consider is the cost of having to go in and fix the Pacesetter leaks you also referred to. Its a matter of what your time is worth and do you want the hassle of dealing with the leaks should they occur.
  15. #15 Re: SLP Headers
    Kansas City, MO
    If you do it right the first time, there's no going back and fixing any problems.
  16. #16 Re: SLP Headers
    Fort Wayne, IN
    The original few batches of SLP headers had the noise issue on the flex piece because they coated the entire part. All of the newer ones arent coated from the flex back and that took care of the noise. I have installed several sets of early and late ones and the cure on the early ones was to wrap the flex in header wrap which took care of it. One thing to not also is other than the better fitment of the SLP headers, you can work around the transmission MUCH better than with TOGs or PaceSetter headers. Pacesetters are a crap design and I hate working around them, ESPECIALLY when the crossover pipes are welded on permenantly to rid the leak problem. Also on the Pacesetters the crossover pipe sits way too low and close to the trans and makes it difficult if not impossible to install a trans temp sensor for a gauges as the threaded end of the sendor will touch the crossover pipe. I wouldnt recommend those headers to anyone, but again price is always a concer and they are by far the cheapest. One other point of interest on the PaceSetters is that the holes dont line up with the heads properly. I discovered this on F-body 3800 headers and they only have 1.5" primary tubes. The center tube is close and the outer two are too far inwards and this leaves poor sealing area and poor port lineup. They must have used the F-body plates and just opened the holes up for the 1 3/4" tube but never corrected the location of the holes to the heads to make sure they line up. Even with over a 1/4" more room to allow for give in the lineup they are still off. This makes matching to ported heads difficult and can hurt exhaust flow. Again you get what you pay for, and I would never pay for those! I would rather wait to save more money up and get parts that fit proper without the headaches.
  17. #17 Re: SLP Headers
    GTP Level Member David99GTP's Avatar
    Florida
    Yeah I have a full exhaust project planned next time around. I need to get the air flowing out before I start forcing lots in.
    I had decided on the SLPs. I have heard a lot of good feedback on them.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  18. #18 Re: SLP Headers
    Fayetteville, NY
    see im the opposite, i have all the flow out...but not too much flowing in, that is why i have things planned for this spring thanks to synthetic helpin me out..
  19. #19 Re: SLP Headers
    Oklahoma
    Oh wow, I got recognized. Did I do good or something?
  20. #20 Re: SLP Headers
    Fayetteville, NY
    lol yeah man
  1. pacesetter headers ?
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2008, 03:02 PM
  2. pacesetter headers ?
    By ryangtp89 in forum General Tech Discussion
    Last Post: 01-04-2008, 04:26 PM
