Thread: Driving on express way at 65 mph, engine dies! What the???
Results 1 to 11 of 11
  1. #1 Driving on express way at 65 mph, engine dies! What the???
    Louisville, KY
    My wife was driving home yesterday on the express way headed home. Speed limit is 65mph. She says that it just died on her while driving. I took it out last night. Drove it for about 30 minutes no problem. Then I was headed home and it died on me doing 45mph. I pulled off the side and restarted it, no problem. Drove about 2 miles down the road again at 45mph, it died. Stopped at gas station and put in 3/4 tank according to the gas guage. It says it had a 1/4 tank in it.
    Anyone had this kind of problem?
    Wasn't overheating, plenty of coolant and oil.
    Gas guage said 1/4 tank and the engine just died not sputtered like it couldn't get fuel.
    Wasn't racing or hard braking, died during acceleration to 45 mph.
    My Cardomain
  2. #2 Re: Driving on express way at 65 mph, engine dies! What the???
    Louisville, KY
    Forgot to add, car has 67,000 miles on it and it's a 2000 GT.
    My Cardomain
  3. #3 Re: Driving on express way at 65 mph, engine dies! What the???
    SE Level Member nsvaldi's Avatar
    denver
    vapor lock?
  4. #4 Re: Driving on express way at 65 mph, engine dies! What the???
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    i had a very similar problem when the coil packs went bad on my cavalier
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  5. #5 Re: Driving on express way at 65 mph, engine dies! What the???
    Hoffman/Schaumburg, IL
    sounds like a crank postiion sensor, or a ignition control module......unlike a I4 cavalier, a V6 GP will run w/o one coil, very poorly, but it'll run......
    If the Low traction, or ABS light are going on when the car stalls, that is a sign of the Crank pos. sensor....there are testers for the ign. module at autozone and such, but none of them get it hot enough fo it to fail, borrow one from a friend with a known working GP, or an extra to test the ign. module
  6. #6 Re: Driving on express way at 65 mph, engine dies! What the???
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by 02BlueGT View Post
    good to know, thank you
  7. #7 Re: Driving on express way at 65 mph, engine dies! What the???
    Louisville, KY
    I'm going to take the ICM off my 2003 GT and put it on her 2000 GT this weekend and see if I still have problems with it. If not it's probably the crankshaft position sensor or the camshaft sensor.
    Figure I'd go with the most expensive part to replace ($182.00) first and then if I'm still having problems with it on Monday a friend of mine has a HP tuner that were going to do a realtime scan on the crankshaft and camshaft sensors to see what they are sending back. I think they are about 20 and 30 each so for about 60 with tax I could just replace both of them without huring the budget.
    The camshaft should be pretty easy to swap out but I heard the crankshaft is kind of a pain. Anyone got pictures of these areas and any tips on replacing?
    My Cardomain
  8. #8 Re: Driving on express way at 65 mph, engine dies! What the???
    Louisville, KY
    Switched out the ICM. My car isn't dying but my wife's still is. Will try the Crankshaft Sensor first since it's the biggest pain to replace. Always my luck that it's the hardest part to work with.
    Buddy hooked up tuner. As we were driving you could see the RPMs Go from 1900 to 0 in less than a second then the fuel pump would shut off. Don't know how GM calculates the RPMs but its bound to be the Crankshaft or Camshaft sensor, just depends on if GM used one or both for the calculation. Reason why I say it is because the car was still rolling down the road at 65mph in gear when the RPMs said 0. Physically impossible!
    My Cardomain
  9. #9 Re: Driving on express way at 65 mph, engine dies! What the???
    columbus in
    I recently had to replace my crank positioning sensor. One thing that was happening before it finally quit was the tach would drop to zero, while the car was still running. Bet thats your problem.
  10. #10 Re: Driving on express way at 65 mph, engine dies! What the???
    Louisville, KY
    It was the crank position sensor. Also put on a new transmission filter and gasket on the wife's car. It was leaking anyway and since I already had it up on the lift it seemed stupid to not replace it at the time.
    Also did the permanent water leak fix for the passenger side floorboard water leak on both cars. Wife's car got wet last week and since the part price wasn't high bought one for both. Definitely easy to do and well worth it in the long run because now I don't have to worry about my car!
    My Cardomain
  11. #11 Re: Driving on express way at 65 mph, engine dies! What the???
    Louisville, KY
    Car is still running and it hasn't died since I put the new sensor in. Only cost me $25 for the part, $15 for the transmission filter and gasket, $15 for new transmission fluid and $18 for the bay rental.
    My Cardomain
  1. Engine hesitating while driving
    By forgerat1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-23-2010, 11:17 AM
  2. HELP: Starts then dies after LIM
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 06-23-2009, 03:35 PM
  3. Nitrous Express of Wichita Falls Pwns You
    Last Post: 11-16-2008, 09:21 AM
  4. Car Dies out!???
    By letsndy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2008, 03:47 PM
