Thread: replacing CPS, can/ should I replace front seal then?
Results 1 to 3 of 3
  1. #1 replacing CPS, can/ should I replace front seal then?
    Feb 2009
    NE
    High mile car. Has phonton no start issue. GOing to replace the CPS. Shouls/ can I replace the front seal then? Any tips?
  2. #2 Re: replacing CPS, can/ should I replace front seal then?
    I wouldn't replace the front seal if it's not leaking. Currently it's worn in to the balancer and sealing well right?
  3. #3 Re: replacing CPS, can/ should I replace front seal then?
    Feb 2009
    NE
    I have an oil leak and there is oil around the balancer area. Just wondering if when I get the balancer off it is going to be obvious that it has been leaking and a goods time to replace.
  1. How to replace front hubs
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 03-12-2015, 11:18 AM
  2. S/C Fill Plug Seal
    By VinceJE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2009, 09:17 PM
  3. Need some help on the Reverse Servo Seal.
    By Raz97GT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-29-2009, 07:19 AM
  4. front oil seal
    By sloppyjoe616 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2009, 05:15 PM
  5. Replacing Front Bearing/Hub
    By TMC in forum How To Write-Ups/Tech Tips
    Last Post: 01-13-2009, 01:13 AM
