Thread: Alternator Voltage Booster question
Results 1 to 19 of 19
  1. #1 Alternator Voltage Booster question
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    Im thinking about buying one of these from zzp but i was wondering since i dont have the big three in my car yet will the smaller wire be able to handle it? my next question is should i get the big three first? i cant really do both at the same time do to money so i was just wondering if the stock wiring can handle the voltage booster or if i should just do the big three first.(im aiming to get my car to get 30's for gas miliage and im at 26.5 now and i read that this could move it up as much as 2 mpg) so what do you guys think?
    silver 2003 Grand Prix GT List is on it's way to be updated
  2. #2 Re: Alternator Voltage Booster question
    Outer Space
    I got the stage 2 booster on my 02 gtp. The only wiring I have is an Alt Rewire. Everything is ok for mine.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Alternator Voltage Booster question
    Get a Powerlog and Downpipe...that'll give you better gas mileage
  4. #4 Re: Alternator Voltage Booster question
    TDCRacing
    Guest
    I have all stock wires with a stage 2
  5. #5 Re: Alternator Voltage Booster question
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    I would just spend the money upgrading the power wires. You do not really need the voltage booster.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  6. #6 Re: Alternator Voltage Booster question
    GT Level Member Going Too Phast's Avatar
    If you feel confident with electrical work you can do the volt booster for the price of a diode (less than a buck):
    ZZ Performance
    I got ZZP's deal so I could easily reverse the mod. I admit I didn't really notice much difference other than my headlights getting a little brighter. In hindsight I'd recommend either the cheap DIY way, or just skip it all together. If you are hoping to gain any mileage, I wouldn't hold my breath. After all the exhaust and intake mods I've done the only thing that has netted me measurable mileage gains was bumping up my timing. YMMV
    .: 1998 GTP : 3.5 : PT : 1.9s : Intake : DP : Plog : 180* : 605s : UD WPP : STBs : 12" Brakes :.
  7. #7 Re: Alternator Voltage Booster question
    Aug 2008
    KCMO
    what does the big 3 do and how do you do it?
  8. #8 Re: Alternator Voltage Booster question
    Nov 2008
    what is a powerlog?
  9. #9 Re: Alternator Voltage Booster question
    Nov 2008
    can you safely run a stage two with a subwoffer and stuff like that?
  10. #10 Re: Alternator Voltage Booster question
    Outer Space
    powerlog.....ZZ Performance i wish i got a kickback on these...You should be able to run a sub on the alt booster.
  11. #11 Re: Alternator Voltage Booster question
    Nov 2008
    are there any web sites out there that sell the big three for a good price. if i can get a good enough deal i might be able to do both. idk about the power log though. id really like to but it really is to much money for me since im going to college this fall
  12. #12 Re: Alternator Voltage Booster question
    Here is what I would do...
    1) Make your own intake...for about $50 or so...get 4" PVC Pipe from Lowe's or Home Depot or whereever and slap a filter on it and shove it in the fender...and be done there...
    2) 180* Thermostat - $10 or so at a local Auto Parts store...you just gotta ask for it.
    3) 3" Downpipe/U-Bend Delete - Bolt-in...or Shorty...if you get a shorty it has to be welded in but they are a lot cheaper
    4) You got a dremel tool? Pull of the front manifold and go to town on the imperfections in it...had mine hooked up to a DHP Powertuner before and after...I dropped 1.1* of KR...now if you don't have a dremel...then go buy one...and after your done, take it back and say you didn't need it See...Free
    5) IF you want to mess with it...get new plug wires and some Autolite 605's.
    6) Another free mod is flipping the motor mounts. There is a thread in here about how to do it but I can't find...it is really easy to do though.
  13. #13 Re: Alternator Voltage Booster question
    Nov 2008
    i ended up buying a diode to put in it just becasue it only cost me a dollar but when i whent to get it at radio schack they had like a 60 volt 100, 200, and 600 volt 1 amp diode. i just bought 1 60 volt and one 600 volt just becasue they had no idea what i was talking about and i didnt know for sure witch one either. so is it just like a fuse where it can only handle say 60 volts or do i need to keep looking and find a 12 volt one?
  14. #14 Re: Alternator Voltage Booster question
    Jersey
    i have a zzp stage2 voltage booster if anyone wants to buy it, pm me.
    16' wrx sti- stock
  15. #15 Re: Alternator Voltage Booster question
    Nov 2008
    any ideas guys id like to get this put in before i go on my road trip?
  16. #16 Re: Alternator Voltage Booster question
    Houston, TX for now
    Quote Originally Posted by kjohnson View Post
    Yes, Sometimes there is a little ground feedback though. I overhauled the ground on the car and it cleaned it right up.
    I don't remember off the top of my head the size of the diode. But no you don't need a 12 volt. We'll use this as a bump and see if somebody else can help.
    2000 GRAND PRIX GTP COUPE WITH THE NORMAL LIST MODS TO MAKE IT LOUDER, FASTER AND OF COURSE SEXIER!! 267 WHP @ 9000 FT ABOVE SEA LEVEL
  17. #17 Re: Alternator Voltage Booster question
    Nov 2008
    come on guys i know you guys have done this mod before which one should i use? will the 1 amp 60 volt one work?
    plz help
  18. #18 Re: Alternator Voltage Booster question
    Nov 2008
    bump
  19. #19 Re: Alternator Voltage Booster question
    Waynesboro, PA
    What are the numbers on the diode?
  1. Alternator voltage boost
    By abuckley1290 in forum General Tech Discussion
    Last Post: 04-04-2009, 02:21 PM
  2. Idle voltage....Alternator?
    By Damojo2003 in forum General Tech Discussion
    Last Post: 12-05-2008, 06:52 AM
  3. Alternator Voltage booster gone wrong
    Last Post: 03-19-2008, 03:44 PM
