Hi all, I have seen similar issues reported by others but the resolutions seem to vary so if anyone can point me in the right direction I would appreciate it.
My daughter complained that her 2001 grand prix was driving "funny". When I finally got to drive it myself it seemed to be starving under a load. If going up a hill it would shift down but not be able to turn more than 2500 rpm or so even stepping the pedal down all the way. Engine seems to rev fine in park. Problem only happens under load. She had the SES light on. She didn't know how long it had been on. There were several codes regarding the EGR and maybe one other. Since she didn't know how long the light had been on I cleared them and drove the car to see what would come back in. The only code that reappeared was P1404. I replaced the fuel filter. Had access to a cheap used but known good fuel pump so I replaced that also. No difference. I removed the EGR. It didn't look too bad but I went ahead and cleaned it up, made sure the pintle moved easily, reinstalled it with a new gasket and did the "reset the sensor position" procedure mentioned in other posts. The SES hasn't reappeared but the engine power problem remains. After reinstalling the EGR it seemed as though the power had improved slightly but still not normal. I do have access to an autotap and a laptop so I can monitor sensors while operating but I don't really know what conditions to look for. Any ideas?
Thx
Scott
