Have auto tap and it gives me data but since I have no reference to compare I am lost.
This thing keeps stalling data from two sensors all over the map
First the tps is flakey it seems most of the time it sit at 0 but then it jumps to .4% angle but it's stalling at both.
The mass sensor also seems out although it was replaced two months ago which corrected the first time the stalling came.
But now for the part of the time it seems to get stuck and stops changing.
Is there some one out there that has a base line scan from AT they could send for comparison. Is it possible the mass could be screwed again so soon?
I’m sure the tps is screwed but this is a buddies car and I want be sure.
I changed the plugs out but the three on front were running lean the back three seemed fine.
All of the hard stuff is fine as far as mechanical goes.
This is a 97 grandprix SE with a 3.8
Error codes are
Code: Description:
P0102 Mass Air Flow Sensor Circuit Low Frequency
P0122 Throttle Position Sensor Circuit Low Voltage
P0171 Fuel Trim System Lean Bank 1
P1122 TP Sensor Circuit Intermittent Low Voltage
P1406 EGR Valve Pintle Position Circuit
--------: FREEZE FRAME DATA :--------
Generated by DTC code: P0102
Fuel System Status Bank 1: OL-1
Calculated Engine Load: 0.8 %
Engine Coolant Temperature: 187 °F
Short Term Fuel Trim Bank 1: -0.8 %
Long Term Fuel Trim Bank 1: 16.4 %
Manifold Absolute Pressure (MAP): 10.6 in Hg
Engine Speed: 854 RPM
Vehicle Speed: 0 MPH
Mass Air Flow Rate: 0.239 lb/min
Throttle Position Angle: 0 %
The mass is indicated where it seems to stick at but a ignition off and restart brings it back to life
I'm beginning to suspect a pcm issue but I have only work on my stuff chryco and i know them pretty well, even if t didn't stall Would from the data I'm getting say this is one sick puppy.
Any thoughts would be of help
thanx
