Thread: AC Compressor
Results 1 to 6 of 6
  1. #1 AC Compressor
    SE Level Member trenaro's Avatar
    Feb 2009
    KC
    Hey guys
    Time to fix the AC. Bought the car 3 months ago. About a month ago I tried to rescharge the system (totally out), and it leaked out in about a week. Took it to a shop for testing and was told it was the condensor. Replaced that and tried a recharge again.
    All of the sudden the compressor started to spew greenish oil out. I know these things could leak, but that much? The color I added to the condensor was blue. Anyway I let it cool for a couple of hours and pulled the tire off so I could get a good view of what was going on, but the compressor will no longer kick on now. It still has freon in it to kick the compressor on.
    Any help with this would be greatly appreciated.
    T
  2. #2 Re: AC Compressor
    Feb 2009
    KC
    C'mon guys please. I need a person familar with AC. I won't take a car to a mechanic. I need this AC fixed and I need advice.
    Thanks
    T
  3. #3 Re: AC Compressor
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Did you have the system evacuated after you replaced the condensor? You have to get the air out. Also, do you know you added the right amount of R-134a?
    AC is one of those things that most of us DIYers will take somewhere. Too much specialized equipment involved.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: AC Compressor
    Feb 2009
    KC
    Didn't get it evacuated after the condensor. I could not find anything about doing that when changing the condensor. I know I will if I change the compressor. Your right about AC's - you need equipment.
    One other thing is when a condensor is changed you need to add 1 oz of oil to it. There is no way to do that unless there is some equipment mechanics use. I was able to add maybe a quarter oz, I then put a small amount in the condensor hose by removing the hose on the back of the compressor.
    I'm thinking this might have overloaded the compressor with too much oil. I'm wondering if this could have fried the compressor???????
  5. #5 Re: AC Compressor
    QCA, IA
    Any time you open the system, you need to evacuate it. With all of the air in there plus whatever you added for oil and 134a, I suppose it could have screwed up the compressor, it's hard to say.
  6. #6 Re: AC Compressor
    Feb 2009
    KC
    With all the info - I think I need to evacuate and start from square one.
    Thanks guys
  1. replacing bad ac compressor?
    By fst in forum Off Topic Discussion
    Last Post: 07-23-2010, 07:51 PM
  2. AC Compressor
    By Willthesage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2009, 02:56 PM
  3. How big of a compressor should I get?
    By FuglyGTP in forum Off Topic Discussion
    Last Post: 03-06-2009, 08:18 PM
  4. air conditioner compressor
    By justwhisen in forum Shops and Community Heroes
    Last Post: 09-03-2008, 07:29 AM
  5. Bad AC compressor??
    By HOPPY in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2008, 07:06 PM
