Thread: Fuel Pressure Regulator Help
Results 1 to 9 of 9
  1. #1 Fuel Pressure Regulator Help
    SE Level Member Latdogg's Avatar
    Great Falls, MT
    Ok, so I have a 2001 Grand Prix GT with the 3.8L V6. It had been running a little rough and occasionally dying when I would be driving. I narrowed it down to the FPR, and bought the part today. Well my problem is, I am having trouble removing the old one. I tried to find instructions with pictures today on the net and have not had much luck. Any help would be appreciated as my car currently wont start, turns over, just wont start.
  2. #2 Re: Fuel Pressure Regulator Help
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Remove snap ring, remove with FPR with pliers in a twisting and pulling motion.
    Lube new one with vasoline
    Install in reverse.
  3. #3 Re: Fuel Pressure Regulator Help
    Great Falls, MT
    Quote Originally Posted by VinnieGTP View Post
    Install in reverse.
    How do I get that snap ring off? It looks like it should be easy to do, but I was having trouble with doing it yesterday. It looks as though you should just be able to pull that old one right out.
  4. #4 Re: Fuel Pressure Regulator Help
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Well, the best way is with a snap ring pliers. You can't just pull it out, there's that snap ring with the 2 holes in it, you need to stick something in those 2 holes and squeeze the ring.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: Fuel Pressure Regulator Help
    Great Falls, MT
    Quote Originally Posted by Scimmia View Post
    Ahh, that makes sense. Thanks man. I will go pick up some of those pliers today!
  6. #6 Re: Fuel Pressure Regulator Help
    Las Cruces, NM
    Or just use a small pair of needle nose pliers if you have them.
  7. #7 Re: Fuel Pressure Regulator Help
    Great Falls, MT
    Alright, I got the part on and the car started right up. Now though there is quite a bit of white smoke coming out of the exhaust when its running. I know I am in need of an oil change, but I'm not sure I should be seeing all the white smoke...
  8. #8 Re: Fuel Pressure Regulator Help
    QCA, IA
    white smoke usually means coolant. Most likely an intake problem, either LIM gaskets or the UIM warped/cracked.
  9. #9 Re: Fuel Pressure Regulator Help
    Great Falls, MT
    Yea, well the white smoke is gone now. I just took it up and got its oil changed. Its running rough though, and when I go to accelerate from a stop it is very sluggish. This car is driving me nuts!
  1. Will this Fuel Pressure Regulator work?
    By Quicklynx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-30-2008, 09:25 PM
  2. Vacuum line for Fuel Press Regulator, where does it go?
    By 97grandprix38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2008, 12:17 AM
  3. Fuel Pressure
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2008, 10:53 PM
  4. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
  5. After Market Fuel Pressure Regulator
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 02:14 PM
