Thread: What is the easiest way to pull a Motor???
Results 1 to 15 of 15
  1. #1 What is the easiest way to pull a Motor???
    SE Level Member GaBear's Avatar
    Dec 2008
    Gainesville, Georgia, United States
    My 97 has blown heads. I've bought another motor to put in while I do repairs to the original motor. How is the easiest way to pull the motor??? I've generally pulled motors out the top with an engine hoist put someone suggested that I jack up the car as High as I can and drop the front end motor, tranny, and all out the bottom. I just don't think My jack stands will get that high.
    BEAR
    97 Grand Prix GT: 2D/ 3.8 Liter/ AutoMatic / Cool Air Intake/ Full Magna Flow Exhaust
    More to come later
  2. #2 Re: What is the easiest way to pull a Motor???
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Pull it from the top. You'll get well acclimated with the ***** bolt but its the best way
  3. #3 Re: What is the easiest way to pull a Motor???
    Dec 2008
    Thats what I thought......
    BEAR
    More to come later
  4. #4 Re: What is the easiest way to pull a Motor???
    Cut it out with a torch...buddy went to buy a motor and the guy asked him if he wanted to hear it running...he didn't care since he was going to build it so he declined...we got there and it was cut out CV Shafts and all LOL
  5. #5 Re: What is the easiest way to pull a Motor???
    Feb 2008
    LOL ***** bolt... I left mine sitting on the toolbox...
  6. #6 Re: What is the easiest way to pull a Motor???
    if you get randy you can just put a ratchet on it and hit it from the front of the motor instead of doing the multi-extension thing from the passenger wheel well. youll need to have the rear valve cover off to do it. it is WAY easier if you just straight up take off the rear head.
  7. #7 Re: What is the easiest way to pull a Motor???
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I don't know what everyone complains about, I thought the so called ***** bolts was pretty simple with a few extensions.
    2001 Buick Regal LS - Almost Stock
  8. #8 Re: What is the easiest way to pull a Motor???
    Banned - Busted For Scamming
    Feb 2009
    yea it isnt hard to do at all, just requires knowing where the damn thing actually is....
  9. #9 Re: What is the easiest way to pull a Motor???
    Dec 2008
    Quote Originally Posted by VinnieGTP View Post
    What Bolt are You talking about???
    BEAR
    More to come later
  10. #10 Re: What is the easiest way to pull a Motor???
    QCA, IA
    Quote Originally Posted by GaBear View Post
    The bolt that goes in from the passenger side between the trans and engine is known as the b itch bolt.
  11. #11 Re: What is the easiest way to pull a Motor???
    Dec 2008
    Quote Originally Posted by Scimmia View Post
    Well That Explains Alot.....Thanks
    BEAR
    More to come later
  12. #12 Re: What is the easiest way to pull a Motor???
    all the other ones go in from the drivers side...what was GM thinking?
  13. #13 Re: What is the easiest way to pull a Motor???
    Was that the day you donated beer to them
  14. #14 Re: What is the easiest way to pull a Motor???
    my ***** bolt story:
    i already had half the top end of my motor off. i put a ratchet on the back side of the motor with the right socket onto the aforementioned bolt. i stood on the ratched and what i thought happened was that the ratchet fell off the bolt. i got a giant gash in my leg from the rear head. after going through the fender well with every extension i could find in the house i realized i had already broken the bolt loose and i could have just taken it out from where i was to begin with.
    when i put it back in i put it in from the front and i didnt tighten it down very much. if it rattled its way out by now i could really care less.
  15. #15 Re: What is the easiest way to pull a Motor???
    Barksdale AFB, LA
    Kinda hard to come from the driver's side when the transmission is in the way...
    2009 Subaru Impreza WRX STI
  1. got pull over today
    By nemesis in forum The Rant Forum
    Last Post: 06-25-2009, 02:59 PM
  2. whats the easiest way (rack)
    By jbmiller in forum General Tech Discussion
    Last Post: 01-04-2009, 01:29 PM
  3. Easiest HP gains
    By mikes_comp_g in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2008, 02:17 AM
  4. pull engine?????
    By kingd44 in forum Off Topic Discussion
    Last Post: 08-10-2008, 09:12 PM
  5. easiest shift kit to install ?
    By bayareagtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-26-2008, 09:18 AM
