Thread: my homemade CAI, opinions??
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 71
  1. #1 my homemade CAI, opinions??
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    i made it for $50. that flexible tubing was $20 at autozone, and the filter was $25. when that tubing is scrunched together its solid as hell so i just clamp the rubber fittings over that. it came with a rubber fitting to go over it so i slid that over the tube, and then put that into the tube that the IAT is in.
    my only concern is that that tubing might not be wide enough. is 3 inches enough or should i have aimed for 4?
  2. #2 Re: my homemade CAI, opinions?
    tubing is too small and pretty restrictive seeing as how it isnt a smooth inner pipe.
    the best intake for you would be a 3" > 4" silicone coupler to a PVC pipe with a 22.5* bend with a straight piece getting it decently close to the fender. being completely in the fender gets the filter super dirty super fast. take off all the bendy tube stuff.
  3. #3 Re: my homemade CAI, opinions?
    memphis
    ^ what he said..
  4. #4 Re: my homemade CAI, opinions?
    Donating Users
    Plainfield, IL
    looks uber restrictive...
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  5. #5 Re: my homemade CAI, opinions?
    Jersey
    your car is suffocating for air.
    16' wrx sti- stock
  6. #6 Re: my homemade CAI, opinions?
    Nov 2008
    Fremont Nebraska
    well thanks for the input guys, back to stock it is! for now.....
    looks like ill be going to the store in search of a piece of 4 inch pvc pipe.
    so do any of you have fenderwell intakes? if so how did you get 4 inch tube through there? or does most everyone have heavily shielded warm air intakes?
  7. #7 Re: my homemade CAI, opinions?
    you have to put a rubber bend on it to fit into the fender decently, but the 90* bend to get into that is the restrictive part regardless of how cold the air is. just get it close to the fender and call it a day.
  8. #8 Re: my homemade CAI, opinions?
    Nov 2008
    Fremont Nebraska
    so is this better then before? better then stock at least?? if so, thats a $33 intake
  9. #9 Re: my homemade CAI, opinions?
    that is better. i would have bought a PVC bend instead of leaving the pipe in there cocked though.
  10. #10 Re: my homemade CAI, opinions?
    Nov 2008
    Fremont Nebraska
    i couldnt find any pvc bends 4 inches thick, i only checked one store though. i might check into that later on but it looking like that doesnt really bother me
  11. #11 Re: my homemade CAI, opinions?
    GT Level Member Merlin's Avatar
    May 2008
    Broken Arrow, OK
    check this sites how-to's for a write up on a uber bomb diggity DIY intake.
    Engineering the impossible.
  12. #12 Re: my homemade CAI, opinions?
    Jul 2008
    Tampa, FL
    ^ yeah, i think its 'street wolf' 's design that i used to base mine off of...check out the pics of mine in my album, it might give you some ideas too...
  13. #13 Re: my homemade CAI, opinions?
  14. #14 Re: my homemade CAI, opinions?
    Nov 2008
    Fremont Nebraska
    now thats an idea! ill use that write up to modify mine for sure when i get some extra $$$ again
    also, while im thinking about it, whats with that screen right at the throttle body? can i tear that out? it just looks like one more restriction....
  15. #15 Re: my homemade CAI, opinions?
    Barksdale AFB, LA
    Quote Originally Posted by Jakegday View Post
    It's the MAF screen. It's used to smooth the airflow as it crosses the MAF so it gets an accurate reading. Leave it in.
    It's also your engine's last line of defense against debris going into the engine. For one of our turbo guys, that's what saved his engine when his turbo ate itself.
    2009 Subaru Impreza WRX STI
  16. #16 Re: my homemade CAI, opinions?
    i dont have a MAF screen, but i have been trying to find someone to sell me a screen and clip so i can see if it makes any difference.
  17. #17 Re: my homemade CAI, opinions?
    Nov 2008
    Fremont Nebraska
    well im a dipsh**, i already tore it out before waiting for any replies. are there any bad things that i should look for to happen now?
    they're $18.32 at gmpartsdirect.com
  18. #18 Re: my homemade CAI, opinions?
    SE Level Member awq134's Avatar
    Cameron, NC
    I took mine out almost a year ago when i put my cold air intake in. Then a few months later i put it back in for the same reason. I didnt' see any change at all so i took it back out. Personally, if something that big wants to get into the engine, a small aluminum screen isn't going to stop it. Besides if you have something that big getting past your filter you have bigger issues.
  19. #19 Re: my homemade CAI, opinions?
    Do you have a stock TB?
    Just wondering b/c if you don't I was told my MAF (LQ4)...if you take the screen off of it...they are supposed to flow nearly twice as much air...I took the screen off of my car when it was stock...not sure about the LQ4 thing...but I left mine on as a LS1 flows JUST FINE
  20. #20 Re: my homemade CAI, opinions?
    i have a stock TB that i hogged out and ported on my own, no external MAF.
  1. Homemade FWI Install Question
    By High Rolling GTP in forum General Tech Discussion
    Last Post: 02-01-2009, 08:51 AM
  2. Homemade shift kit?
    By Bogers99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-05-2008, 01:00 PM
  3. opinions on this??
    By fabz77gp in forum General Tech Discussion
    Last Post: 10-17-2008, 11:57 PM
  4. My homemade CAI
    By kdubhoffy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2008, 05:38 PM
  5. Who's Done Homemade Fuel Rails (With an fittings)
    By RNUOVR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 04:13 PM
