Thread: AC Compressor
Results 1 to 9 of 9
  1. #1 AC Compressor
    SE Level Member Willthesage's Avatar
    Feb 2009
    South Carolina
    So come to find out my AC clutch / Compressor doesnt work,
    and i really dont have the time or money to get it fixed just yet, so I was wondering if it was a bad idea to buy a shorter belt and just bypass the ac unit entirely.
    it makes an aweful noise like the ac clutch is trying to engague but it cant or wont for what ever reason. kinda like metal rubbing on metal.
    Well hope to get a few answers. thanks!
  2. #2 Re: AC Compressor
    you could do that or you can buy an AC delete pulley for like $30.
  3. #3 Re: AC Compressor
    Barksdale AFB, LA
    You can't just bypass the a/c pulley with a shorter belt. Without it the belt would hit the water pump pulley as it goes up from the crank to the alternator. You have to use an AC delete idler.
    2009 Subaru Impreza WRX STI
  4. #4 Re: AC Compressor
    Feb 2009
    South Carolina
    i see, how difficult would that be.
    im pretty good with cars and what not, so im not dumbfounded when i need to do something under the hood.
    but like time period required to do this would be what at a rough estimate?
  5. #5 Re: AC Compressor
    Barksdale AFB, LA
    You need to have your AC system evacuated of freon. After that it's just a few bolts and lines holding the compressor in and you slap the AC delete idler in its place.
  6. #6 Re: AC Compressor
  7. #7 Re: AC Compressor
    Banned - Busted For Scamming
    Feb 2009
    evacuated? just crack the line and let that **** out.
    shame on you.... j/k yea screw those epa bastards.
    Logan
  8. #8 Re: AC Compressor
    Feb 2009
    South Carolina
    okay doesnt seem to bad.
    i will see what i can get done this weekend,
    seeing as how i work the rest of the week.
    fun fun.
    thanks for the help!
  9. #9 Re: AC Compressor
    Jul 2008
    nj
    Damn, I wish I read this post before I changed my compressor. My clutch was making noise so I swapped it out for a new one. Figures, one of the rare times I don't keep something for a little while
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  1. replacing bad ac compressor?
    By fst in forum Off Topic Discussion
    Last Post: 07-23-2010, 07:51 PM
  2. How big of a compressor should I get?
    By FuglyGTP in forum Off Topic Discussion
    Last Post: 03-06-2009, 08:18 PM
  3. Bad AC compressor??
    By HOPPY in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2008, 07:06 PM
  4. AC Compressor replacement????
    By 03renegade800 in forum Off Topic Discussion
    Last Post: 06-26-2008, 03:18 AM
  5. Reccomend me an air compressor
    By Andrew_99GTP in forum Off Topic Discussion
    Last Post: 06-05-2008, 10:23 PM
