Thread: couple questions on my gt
Results 1 to 14 of 14
  1. #1 couple questions on my gt
    chi-town
    picked it up recently and am working out a few small problems ,
    1. heat only works on high , nothing on 1 thru 4. i bought a blower motor resistor but havent had a chance to put it in yet , pretty common on these cars ?
    2. very intermittantly while drive the tach goes to zero and the traction off light comes on and they both stay on till i turn the car off and restart it. then it could be weeks till it happens again. what could be causing this and where do i even start to diagnois it ?
  2. #2 Re: couple questions on my gt
    Saraland Alabama
    number 1 is more than likely the resistor. The tach I am not sure
  3. #3 Re: couple questions on my gt
    SE Level Member chitownchevy's Avatar
    Chicago
    Quote Originally Posted by archemedes View Post
    x2 the first one is almost definatly the resistor, and the tach could be something wrong with the gauge cluster itself.
  4. #4 Re: couple questions on my gt
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    #2 i kinda have that same problem its probably your Crankshaft Position Sensor.
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  5. #5 Re: couple questions on my gt
    Oklahoma
    First issue I will concur is the Blower Motor Resistor, I just got finished replacing that sucker this past weekend.
    Second issue I will almost guarantee you is the CPS. My car did exactly as you described when I first got it. I just replaced it again at the first of this year no less. In fact there is a how to in the How To section obviously on how to replace that sensor.
  6. #6 Re: couple questions on my gt
    SE Level Member 1998gpgt's Avatar
    McHenry, IL
    The fan problem could also be caused by a bad ignition switch. I had been having the same problem of the fan only working on 5. I figured it was the resistor but had been too lazy to swap it out. But as soon as i installed my new the ignition switch, the problem went away. Now im not saying that the resistor isnt the problem, but if it doesnt fix it you might wanna take a look at the ignition switch.
    1998 Grand Prix GT 337whp/363wtq 12.952 @ 112.02
    2000 Grand Prix GT & 2007 Grand Prix GT
    2004 GTO 13.610 @ 102.69
    1985 Cutlass 455/TH350
  7. #7 Re: couple questions on my gt
    I live here. UR LOSN's Avatar
    Rockford, IL
    I was thinking the same thing^^^^^^^^
  8. #8 Re: couple questions on my gt
    chi-town
    Quote Originally Posted by 1998gpgt View Post
    some one told me this was also a posibility and i thought they had lost their mind. guess i was wrong . i'll do the resistor and hopefully that'll do it , if not as soon as it warms up i'll try the ignition switch.. today its -2 outside so the heat being stuck on high is NOT a problem.
  9. #9 Re: couple questions on my gt
    Oklahoma
    Quote Originally Posted by 59chevy View Post
    Im going to save you some hassle if you will listen to me. I dont have the pictures here with me but I will post them up once I get home if I dont forget.
    Go get yourself either a flexible shaft nut driver (one that you can just pop a socket on and go) or a swivel head driver and an adapter to use sockets with. The bolt heads are 5.5mm, not a common size so get you one of those too.
    There is one bolt on the resistor pack you can clearly see and clearly get to on the front side (closest to the glove box) and you have to completely remove it. There are two on the back side (closest to the firewall), one of which you should be able to see and one I doubt you will be able to. It is with these two that the flex shaft driver will come in handy. I would only LOOSEN them. Then you should be able to get the resistor pack out.
    The two bolts you can see tighten back up when you install the new resistor. The third one (the one you cant see) I would encourage you to leave loosened. It will be a major major bear if you dont have a tool that can flex and get to those two back side bolts.
  10. #10 Re: couple questions on my gt
    chi-town
    thanks for the pointers on the resistor , input from someone thats been there is always helpful. having the correct tools is not a problem , finding the time and mother nature cooperating are the factors. thanks for the help synthetic.
  11. #11 Re: couple questions on my gt
    Oklahoma
    Not a problem. Glad to help out. If I was closer Id come over and help out.
  12. #12 Re: couple questions on my gt
    PA
    Sorry I am a little late on this.
    But typically the blower only working on #5 is a bad blower motor resistor. And typically the tach dropping to 0 and the TCS light and what not coming on is a CPS (crank position sensor) going bad. Not always...but typically.
    2001 GSE
  13. #13 Re: couple questions on my gt
    chi-town
    cps would make sense also , right after i got it i was driving down the highway and the turd .... i mean gp just shut off. coasted off to the side and cranked a couple times and nothing , had starting fluid in the trunk and tried a shot of that , nothing. two minutes later it fired right up and hasnt done it since. looks like i better go find that thread i saw about replacing the cps and read up. man good thing i got this thing on the cheap cheap....
  14. #14 Re: couple questions on my gt
    chi-town
    thanks for these pointers , did it today at work and resistor it was a bad resistor. was exactly as you said it was , one easy , one kinda easy , and one left loose...
    thanks for the help guys and thanks for the pointers.
  1. Replies: 24
    Last Post: 06-12-2008, 10:50 AM
  2. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
  3. IPW questions
    By fst in forum PCM Tuning
    Last Post: 01-11-2008, 06:44 AM
  4. Need a couple PN's.....
    By Iron Indian in forum Off Topic Discussion
    Last Post: 01-02-2008, 09:55 AM
