Thread: Engine Temperature Normal Range...
Results 1 to 7 of 7
  1. #1 Engine Temperature Normal Range...
    SE Level Member Chris's Avatar
    Apr 2009
    Ontario Canada
    Hi All,
    I have noticed that my engine temp gauge reads about 80 degrees when driving. It climbs to about 90-95 when idling... now I know that it will fluctuate some when driving, but that seems a large difference. I've seen it stay pretty low for a while when driving between the 70 and 80 mark. Someone mentioned that my thermostat may need to be replaced, but I thought I'd check here for additional opinions.
    I've only had the car for about a week, so I'm not sure what to expect from it gauge wise yet.
    Thanks!
    Chris
  2. #2 Re: Engine Temperature Normal Range...
    TDCRacing
    Guest
    Where are you getting those readings from? An aftermarket gauge?
    These readings are in *F correct?
    That is not normal operating temps. What's the factory gauge read?
  3. #3 Re: Engine Temperature Normal Range...
    Barksdale AFB, LA
    He's in Canada, so it's Celsius.
    In Celsius, normal is around 90-95.
    2009 Subaru Impreza WRX STI
  4. #4 Re: Engine Temperature Normal Range...
    TDCRacing
    Guest
    Good eye.
  5. #5 Re: Engine Temperature Normal Range...
    GT Level Member chad27's Avatar
    Apr 2009
    gpt,ms
    Mine runs around 180F seems to cool to me
  6. #6 Re: Engine Temperature Normal Range...
    TDCRacing
    Guest
    Quote Originally Posted by chad27 View Post
    You may have an lower temp thermostat installed.
  7. #7 Re: Engine Temperature Normal Range...
    Apr 2009
    gpt,ms
    heck it dont get cold here any way so thats good with me
  1. Temperature Problems
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-19-2010, 10:55 AM
  2. right temperature to put on overlays?
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 02-08-2009, 01:33 PM
  3. 05 GTP Comp G OEM Remote Start Range
    By Jester331gt in forum General Tech Discussion
    Last Post: 01-04-2009, 08:54 PM
  4. plug heat range question
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2008, 03:03 AM
  5. Pictures.. engine look normal?
    By golden_c_ninja in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2008, 07:21 PM
