Thread: Which oil filter?
Results 1 to 20 of 32
  1. #1 Which oil filter?
    SE Level Member Pontiacman's Avatar
    Amarillo, Texas
    Hey guys how is it going? Rightnow I am using a ac delco oil filter and was wanting to try another brand. I have been reading up on the K&N oil filter and the M1 filter. I have read a few things on the WIX filters and a lot of people like them. Should I just stick with ac delco or try something else?
  2. #2 Re: Which oil filter?
    Jersey
    I use either acdelco, or if i want to splurge i get the mobile 1
    16' wrx sti- stock
  3. #3 Re: Which oil filter?
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    acdelco if I dont stop at the shop before I take it in, if I stop its only WIX.
    Its the only two ive ever used, including tranny filters.
  4. #4 Re: Which oil filter?
    Donating Users RedLedbetter's Avatar
    Feb 2009
    Illinois
    Quote Originally Posted by 99prixgt View Post
    ^^X2
    ive never used the K&N but i might try it out my next oil change
    SPREAD THE JAM
  5. #5 Re: Which oil filter?
    chicago
    ac delco or mobile 1 are what i used
  6. #6 Re: Which oil filter?
    Aug 2008
    60118 NE Illinois
    I am still skeptical on the K&N oil filters..
    there are only a couple filter manufacturers, acdelco are private label wix filters.
    the worst filters to use all around are fram, I think if you stay way from fram you should be ok.
  7. #7 Re: Which oil filter?
    chicago
    i used fram on my hunduh but i'm going to start using purator my next oil change
  8. #8 Re: Which oil filter?
    Aug 2008
    60118 NE Illinois
    Its a wonder how fram filters. i used to use em years and years ago on my sbc astrovan had I used even a stocker that engine would still be alive.
  9. #9 Re: Which oil filter?
    Barksdale AFB, LA
    I've used ACDelco, STP, K&N, Amsoil, and Wix. All good. If someone tries to sell you a Fram, take it from them and crush it against the side of their head.
    2009 Subaru Impreza WRX STI
  10. #10 Re: Which oil filter?
    Dec 2008
    Lawndale, CA
    I stick with the delco here. I have used K&N and mobil 1 as well. I used the mobil 1 when autozone had a deal going on when buying mobil 1 oil and getting the filter free.
  11. #11 Re: Which oil filter?
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    I use mobil 1 extended, my next oil change I'm going to use Napa gold on the advice of Overkill. On powerblock tv they showed some rp oil filters, I may try them since I use their oil.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  12. #12 Re: Which oil filter?
    Jersey
    Quote Originally Posted by Sabrewings View Post
    lol autozone guy tried more than once, I think I will smash it on his head next time.
    16' wrx sti- stock
  13. #13 Re: Which oil filter?
    Aug 2008
    Long Island, New York
    Royal purple makes good filters, WIX, and K&N
  14. #14 Re: Which oil filter?
    i use fram because im cheap and i dont care if i destroy the block i have in the car right now.
  15. #15 Re: Which oil filter?
    Amarillo, Texas
    I am trying RP in my car and for what I paid for it I want to get the most out of the oil. Every car I have owned I have used AC Delco and never had eny trouble with it. I don't know how many miles I could go on the filter. I just want something that will go at least 6k miles. Will the ac delco last that long?
  16. #16 Re: Which oil filter?
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by Pontiacman View Post
    I change my oil about every 6000 miles and I use the delco filter. It does its job. I also use mobil 1 synthetic oil.
    FYI Autozone currently has a sale on oil and a filter. Buy 5 qts of Castrol Syntec and a K&N filter for $29.99. Sale is from March 12th - April 8th 2009.
  17. #17 Re: Which oil filter?
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Then use a WalMart SuperTech filter. It is cheaper, and a much better filter.
    I tend to run a Mobile 1 filter on the GTP. The M102 has a slightly larger capacity, too.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  18. #18 Re: Which oil filter?
    SE Level Member beast3300's Avatar
    lmao, X2
    Black 98 Regal GS: best run 13.95@99.75
    99 Red GP L36: 15.5 in 1/4
  19. #19 Re: Which oil filter?
    Amarillo, Texas
    Thanks for all your impute guys.
  20. #20 Re: Which oil filter?
    Dec 2008
    Lawndale, CA
    Royal purple just came out with a filter as well. Not sure how good it is. but Pep Boys is currently offering a special of 5 qts of royal purple oil with a royal purple filter for $49.95.
  1. what filter is best?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2009, 11:50 PM
  2. S.O.B. Fuel Filter
    By quiksilvergt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2008, 01:16 PM
  3. What K&N Air Filter To Use
    By SG2000GTP in forum General Tech Discussion
    Last Post: 06-01-2008, 06:00 PM
  4. Anyone have an S&B filter?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 04-12-2008, 07:18 AM
