Thread: Valve Spring replacement...
Results 1 to 9 of 9
  1. #1 Valve Spring replacement...
    Moore, Oklahoma
    Where do you get an air hold tool to screw into a spark plug hole? I know it needs to be be long to reach the hold, a standard parts store version won't work. Will a no fouler work??
    Also, which valve spring tool do you recommmend? The pry bar style or the cork screw style? Which is the easiest, especailly for the rears? I'm loooking to get all this stuff fairly local.
    FYI, i'm installing CC 105 Springs, Retainers, Viton valve seals, PRJ rocker bolts for my 1.9 rocker setup.
    Shawn
    Shawn W. Larsen
  2. #2 Re: Valve Spring replacement...
    Oklahoma
    Crap, I'll watch this thread with anticipation as Im going to be doing valve train upgrades before long.
    As for the air hold tool, I dont recall seeing any locally but I have seen them on summit. I know you wanted to get it locally, but is this what you need:
    Moroso Spark Plug Air Hose Kits: MOR-62385 - summitracing.com
  3. #3 Re: Valve Spring replacement...
    I live here. UR LOSN's Avatar
    Rockford, IL
    as far as the air tool for the spark plug thread.....you can pick it up at any parts store...should be part of a compression check kit.
    I recomend the cork screw type....it fits into small spaces quite easily...just watch out for the valve locks...they like to fly everywhere
  4. #4 Re: Valve Spring replacement...
    Moore, Oklahoma
    ttt
    Shawn W. Larsen
  5. #5 Re: Valve Spring replacement...
    Bastard Reptile's Avatar
    Kansas City, MO
    I've got both compression tools. I honestly prefer the pry bar type. Thread the bolt in, compress, use a magnet to pull the locks out and pull the spring.....then reverse.
    Too many times have I had springs want to pop off of the corkscrew type, and that really hurts when you're not wearing gloves.
    Also, yeah, compression tester kit. Get one that is made out of a rubber hose, not nylon. It'll make it easier to twist when you're threading it into the heads.
    And don't forget to take the schrader valve out of the end of it.
  6. #6 Re: Valve Spring replacement...
    Oklahoma
    Brian, can you show us a pic of the pry bar type so we know what to look for?
  7. #7 Re: Valve Spring replacement...
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    Never done valves on the car is the compression test kit to hold the valves up?
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  8. #8 Re: Valve Spring replacement...
    Kansas City, MO
    This is what it looks like. You can pick these things up at O'Reillys for like $10...
  9. #9 Re: Valve Spring replacement...
    Oklahoma
    Oh, awesome. Ive seen those before. Thanks Brian.
  1. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  2. stock valve renewing?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2008, 12:51 PM
  3. Fel-Pro Premium Valve Stem Seals-Anyone use them?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2008, 07:50 PM
  4. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
