Thread: EGR Valve! What does it do?
Results 1 to 11 of 11
  1. #1 EGR Valve! What does it do?
    Oct 2008
    Mt Carmel,TN
    I'm getting a code for a stuck EGR Valve. anyone else had this problem and does it need to be fixed. The car seems to run fine, maybe a little hesitation when you first pull out!
  2. #2 Re: EGR Valve! What does it do?
    you can take a wrench and hit it a few times and see if it gets unstuck, but otherwise they are cheap as crap to replace with a use one. i think i have one sitting in the back of my garage if you need one.
    the EGR is really only active when youre cruising. it lets a little bit of exhaust air into the cylinders to help your MPG. i took mine off and left it off and didnt notice a significant drop in mileage or anything.
  3. #3 Re: EGR Valve! What does it do?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    The EGR Valve is there to recirculate some of the exhaust gasses back into the intake, actually lowering combustion chamber temperatures. It reduces NOx formation, since those compounds are only formed above ~2500F.
    First thing I would try is pulling it off and spraying it with carb cleaner. You can also push it up and down manually while you have it off, together with spraying it out, it may clear up your problem. If not, find a good used one.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: EGR Valve! What does it do?
    Barksdale AFB, LA
    Quote Originally Posted by Scimmia View Post
    100% correct. Exhaust gas is inert. So the PCM can reduce the fuel going into each cylinder because less oxygen is present. The exhaust gas acts as a "filler" and helps boost your MPG. It also lowers the combustion chamber temps because less fuel is used (less heat).
    2009 Subaru Impreza WRX STI
  5. #5 Re: EGR Valve! What does it do?
    Apr 2008
    Chillin at the Beach , VA
    Dealer told me it won't hurt any thing. You'll just get stuck riding around with your ses light on. On mine it seems I maybe lost 1 mpg.
  6. #6 Re: EGR Valve! What does it do?
    Barksdale AFB, LA
    Mine is disabled in the PCM. I didn't notice any change. Still get like 33MPG on the highway. When I top swap I will be totally removing the EGR so I don't have it adding exhaust crud to my nice and fresh intake parts.
  7. #7 Re: EGR Valve! What does it do?
    Apr 2008
    I think once I get a good tune on mine, it'll go back up. When I go IC, I'll be removing mine also. How soon before you do you TS.
  8. #8 Re: EGR Valve! What does it do?
    Barksdale AFB, LA
    Quote Originally Posted by BADAZGTP View Post
    First part of April.
  9. #9 Re: EGR Valve! What does it do?
    Apr 2008
    That's things going to be bad@$$. Gonna get some video after it's done?
  10. #10 Re: EGR Valve! What does it do?
    Barksdale AFB, LA
    Pics and video or it never happened.
  11. #11 Re: EGR Valve! What does it do?
    Apr 2008
    Sweet!!!!
  1. EGR valve
    By cobra8432 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-23-2011, 11:12 PM
  2. Valve Cover
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 09:15 PM
  3. EGR Valve?
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 10:24 PM
  4. Is There An EGR Valve Workaround For a '97?
    By 1997gpgt in forum Off Topic Discussion
    Last Post: 08-25-2008, 07:41 AM
  5. Location of PVC Valve
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 08:49 AM
