Hello! I've been dealing with a no spin and a parasitic power draw on a 2002 Grand Prix 3800 v3 and I've run out of ideas. I'm thinking I have a short somewhere, but I haven't been able to track it down. I hear a click that sounds like it comes from the fuse box, but nothing from the starter.
It initially started with the engine having a random delay in trying to start. Sometimes it would fire right away, other times it would be a 2-3 count before anything would happen. That 2-3 count turned in to a 10-15 count which then progressed to no spin at all. As far as the parasitic draw, I've put a new battery in the car and it was dead in about 6 hours. I'm assuming the issues are related, but I have no proof of that.
Things I've done so far:
Tested the battery - Advanced auto was getting inconsistent readings. The first time, their tester read over 1400 CCA, the second time was a more normal 740. Their tester also kept having trouble maintaining a connection with the positive. They thought maybe the battery had a bad cell. The battery was still under warranty so Costco swapped it out, didn't make a difference.
Replaced battery cables (the old positive was mangled)
Alternator - all good
Fuses - pulled and inspected plus checked with a multimeter
Starter - tested good
So that leads me to believe I have a short somewhere. Unfortunately electronics aren't something I've dealt with much so I'm at a bit of a loss. Any advice would be greatly appreciated!
