I have an 07 3800 na and i just changed upper lower intake gasket. Problem is the coolant is coming out infront of tstat housing just above the plenum gasket.... thought that was just air. Any feedback would be appreciated need it back asap
Thanx
Thanx
Little confused where the coolant is actually coming from, but in that area it flows up out of the lower intake into the upper intake and then to the throttle body.
Lol...... ended up i had a little dab of copper hi temp from lim that got on the top gasket. I guess it was just enough to lift the corner just abit. Lots of fun when everythings back together.
