Thread: Fuel gauge not working after car sat for a couple years
Results 1 to 7 of 7
  1. #1 Fuel gauge not working after car sat for a couple years
    Nov 2019
    United States
    I have a 99 Grand Prix 3.8 2 door, been in the family since 2001. Back when the 3rd recall on these came out for the oil leak and fire the car was parked for a couple years. This spring I got it out and have been driving it since with a few minor bugs here and there but nothing I haven't figured out. About a month of being back on the road, the fuel gauge would randomly drop to E then up to full then read accurately. This went on for several weeks with no rhyme or reason as to why it would stop and start reading correctly. Then it finally stopped altogether. Every time I start the car the needle is at full and slowly drops to E unless I'm in P or N, then for whatever reason it's a pretty quick drop. Sending unit and pump were replaced right before the car was parked and all tested fine last week when I was having wiring issues at the plug on top of the pump. Now there is a resistance going through the plug that changes as the float goes up and down like it should. What is the next step to diagnose this? I've heard speculation from others as to the cluster and various things but I hate wasting time and money throwing parts at something. Any help would be greatly appreciated.
  2. #2 Re: Fuel gauge not working after car sat for a couple years
    Apr 2015
    Columbus, OH
    You said the sending unit was replaced right before you parked it? How long was it parked? Sounds like you said years. I'd say your sending unit is bad again. Especially if the gas tank wasn't full. All the symptoms sound like a bad unit. If the wiring and sending unit are bad, only other thing it could be is the cluster, right? The PCM/BCM doesn't have any control over the fuel gauge, I think.
    Top Swapped 01 Imp
  3. #3 Re: Fuel gauge not working after car sat for a couple years
    Nov 2019
    United States
    What happened was the new fuel pump had a slightly different plug so I modified it so that the new pump worked with the OE wiring. In doing so, I didn't realize it had the ability to wiggle loose. I found that out about the same time the gauge completely quit because I went to speed up to pass a car and the car completely died and wouldn't restart. I did a few quick fixes which didn't permanently fix the fuel pump issue so when I finally did a proper fix that has now resolved the fuel pump problem, I kinda expected the gauge to work but it still doesn't. Wiring at the tank is good, probed the wires after they were connected, and when the sending unit was out I checked the resistance and it changed when I moved the float and the resistance stayed constant when I held the float still. So next step is the cluster? Is there a way to test it first? Am I correct with the resistance test on the sending unit?
  4. #4 Re: Fuel gauge not working after car sat for a couple years
    Apr 2015
    Columbus, OH
    How long was the car parked? And did it have a full tank of gas? You are measuring a variable resistance, that's correct. But I wouldn't trust that alone. Maybe it's fine when it's out but in a running car there are other variables like vibrations and other Gremlins. But maybe there are some cracked solder connections on the cluster through pins. I've seen other situations where people fixed clusters by just reflowing the solder on the pins. I'm personally thinking it's the fuel canister because you mentioned bad connections and stuff. Start at the most obvious.
    Top Swapped 01 Imp
  5. #5 Re: Fuel gauge not working after car sat for a couple years
    Nov 2019
    United States
    I think it was about half full and it sat for about 5 or 5.5 years now that I think about it. It was ran for inspection each year but that's about it. I'll check into the cluster. I don't know if I'm not quite understanding you but other than vibrations, I don't see why the canister would still be an issue. I fixed the prior modification that I had with a proper, permanent fix and checked for resistance in the body harness past where it plugs into the top of the pump with everything reassembled. Is there a good place to get wiring diagrams so I can check the connection further up? Possibly up to the cluster?
  6. #6 Re: Fuel gauge not working after car sat for a couple years
    Nov 2019
    United States
    I did get the issue solved finally. I forgot about a wire I had traced back when I was diagnosing the fuel pump issue that I had after getting the car back on the road. The harness that, IMHO stupidly, is located between the bottom seat cushion and metal structure of the car that the cushion rests on had a snapped wire while I was testing. I thought it was just to the rear speakers because the one will intermittently work if someone is sitting in the back seat and the other never does so I just skipped over it at that point. I reconnected that wire and a couple others which had broken apart and that resolved the issue with the fuel gauge and the FTP sensor code that I had. I admit, I was a very hyper little kid and did a lot of bouncing around back there but I feel like GM could've placed the harness beside the seat at least.
    Anyway, figured I'd post this so maybe it'll help someone out in the future.
  7. #7 Re: Fuel gauge not working after car sat for a couple years
    Apr 2015
    Columbus, OH
    I like to think that I busted some wire harnesses when I was younger. I bounced a lot in the back seat, too.
    Top Swapped 01 Imp
  1. fuel gauge not working and radio wont turn on
    By tzerilli in forum Audio, Security & Visual Electronics
    Last Post: 08-09-2019, 10:33 PM
  2. Fuel gauge not working.
    By camopaint0707 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2014, 05:45 AM
  3. 01 bonneville fuel gauge not working right
    By dsmuts in forum General Grand Prix Discussion
    Last Post: 06-30-2012, 11:29 AM
  4. Tach & Fuel Gauge Stop Working
    By Confusingboat in forum General Tech Discussion
    Last Post: 09-15-2011, 04:15 AM
  5. Tranny Stopped working today. Couple ??'s
    By fergup in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-04-2008, 11:56 AM
