Thread: Knock Sensor 1 and Low oil level sensor
Results 1 to 2 of 2
  1. #1 Knock Sensor 1 and Low oil level sensor
    Oct 2019
    NJ
    Hi, newbie here.
    just got a 2005 GT 3.8L. Needed a lot of things as it had sat for 5 years outside under a tree.
    When I look at the wiring,the low oil level sensor and knock sensor 1 have about 6" of wire and then are broken.
    I cannot find the other side of the harness. Nor can I find info on that part of the PCM wiring.
    I think that there is a sub assembly harness for these. Does anyone have a diagram or knowledge of where these wires go?
    Greatly appreciate it.
  2. #2 Re: Knock Sensor 1 and Low oil level sensor
    Is there a harness that runs along the bottom of the radiator and cradle?
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. oil level sensor
    By 04silverprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-19-2012, 06:40 PM
  3. Oil Level Sensor Problems
    By UCF04GPGTPCompG in forum General Tech Discussion
    Last Post: 09-27-2012, 08:56 AM
  4. Oil level sensor question
    By basshead42 in forum General Tech Discussion
    Last Post: 06-07-2012, 06:47 PM
  5. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
