Thread: Water Pump long bolt thread lock
Results 1 to 4 of 4
  1. #1 Water Pump long bolt thread lock
    May 2012
    Bloomington, IN
    The thread lock you should use for the long bolts on the water pump is that the blue thread lock that Loctite makes.
    Please let me know I want to make sure you I use the right and or best stuff for the application.
  2. #2 Re: Water Pump long bolt thread lock
    this is what you need to use. any brand with "pfte" clean the old stuff off the bolts as well as you can too.
    Buy Sealants - Free Shipping over $50 | Zoro.com
  3. #3 Re: Water Pump long bolt thread lock
    May 2012
    Bloomington, IN
    thanks
  4. #4 Re: Water Pump long bolt thread lock
    stuffs good to have around, use it on lim bolts as well as oil pan bolts.
  1. Lock pulley top remove 24mm bolt?
    By rpapy33 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-31-2016, 11:20 AM
  2. Water pump bottom right bolt
    By Tsquared150 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2013, 09:58 PM
  3. Bad water pump,wrong water pump? 2002 GTP
    By R STARR in forum Introductions/Noob Questions
    Last Post: 06-03-2013, 06:47 AM
  4. New prix comes with problems..key lock..Oil pan bolt...
    By chicagochuck in forum General Tech Discussion
    Last Post: 04-04-2013, 06:41 PM
  5. Either a lock or ban on gtryda's Thread
    By nawarkk in forum Forum Bugs/Suggestions
    Last Post: 10-29-2009, 12:21 AM
