Just like the title says. I'm seeking a step by step guide on removing and replacing the water pump. I'm
really trying to make this go as smooth as possible. Thank you.
Edit: It's for a '07 Grand Prix
break free the 4 pulley bolts in the water pump pulley, then take the belt off, then take the power steering pump off, then take the water pump bolts out, the 4 long bolts, coolant will come out these holes, its normal. you want to use some thread sealant on these 4 bolts when re installed. clean the timing cover well. use a new dry gasket, make all your bolts tights and your done. get your belt back on and then make the 4 little pulley bolts tight.
Water pump pulley bolts are 8mm
Long bolts are 13mm
Smaller bolts are 10mm
Power steering pump bolts are at 12 and 6 through the pulley with a 13mm
It's actually very easy. We took the bolts off the coolant reservoir and moved it out of the way, then took the alternator off because it was in the way. Iirc, that was the only extra work required. Once those two things are out of the way the pump is pretty accessible. You may need to remove your passenger side wheel for easier access to the bottom bolts, and I recommend either getting Gates or Dorman metal coolant pipes to replace the plastic ones while you're swapping the pump.
Sent from my LM-G710VM using Tapatalk
