Hi Guys
Where can I get a new cover for my 2003 GT 3800 Series II?
Thanks in advance
#2
Re: 3800 II Cover.....
Turbo is the way to go.
06-08-2018
You can't get new covers, they don't make them anymore. It's way past the 7-8 year mark that GM has to continue making factory parts for these cars.
Finding a new used one from someone else is possible though.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#3
06-08-2018
that one looks perfect. fwiw if you want another to do something to.. just hit up a junkyard
#4
I believe part of the last "engine fire" recall where they replaced the front valve cover gasket also called for removal of that engine cover. At this point good luck finding one in a junkyard
#5
08-11-2018
digitalgpbandit
How many would you like? Junkyards in this area still have 3800's and that's a standard NA engine cover.
08-11-2018
You can get S3 covers off lucernes and cars like that.
Why? I pulled mine off. If it wasn't 1000 miles away in a storage unit, I'd gladly sell it to you for cheap. It's been off for most of the eight or nine months I've had the car and I've had zero issues driving without it.
Sent from my LM-G710VM using Tapatalk
#8
funny you post this because a guy in UNYCGP just posted that he found his in the attic, its been there for 10 years.
Do I need to get you two in touch?
"Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
