Thread: Need help with a P0300 code
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #21 Re: Need help with a P0300 code
    SE Level Member derpyimp's Avatar
    Nov 2017
    Utah
    I just got done swapping over my coil packs and ICM from the Pontiac to the Impala. It's still misfiring, and I know those parts are good. Any other ideas? Anyone know if the computer would throw a code if the crank position sensor was bad?
    '04 GTP Comp-G - 14.871 @ 93.30 (6600 ft DA) - 3.6 MPS, SD headers w/ high-flow cat, Gutted stock airbox, Transgo shift kit, AL 104s, 180 tstat, GMPP front sway bar, poly control arm bushings, Tune by Dyno Brian
  2. #22 Re: Need help with a P0300 code
    Nov 2017
    Utah
    Also, here is a scan of it misfiring at WOT. You can see where the engine RPM starts to struggle and the MAF readings match it.
    http://i346.photobucket.com/albums/p...psgkpl64zm.png
  3. #23 Re: Need help with a P0300 code
    Nov 2017
    Utah
    Just pulled all the spark plugs, regapped them from 0.060 to 0.045 and reinstalled them. Still misfiring badly, now even at idle.
  4. #24 Re: Need help with a P0300 code
    Nov 2017
    Utah
    Tried taking off the oil fill neck while the car was running to see if the engine reacted at all. It didn't do anything. Also no noticeable coolant loss, so I don't think it's the LIM gasket. Tried unplugging PCV while it was idling, then driving around to see if the valve was opening too much. Still missed. I'm running out of ideas lol
  5. #25 Re: Need help with a P0300 code
    Kemmerer, Wyoming
    I'd go smell the exhaust, if the catalytic converter is bad it will smell like rotten eggs.
  6. #26 Re: Need help with a P0300 code
    Nov 2017
    Utah
    Just tried it, smells okay to me. The car also doesn't feel sluggish like a clogged cat would do to it. It just starts missing really bad.
  7. #27 Re: Need help with a P0300 code
    pull the o2 sensor out the manifold, then drive it, if the misfires stop or are reduced, its a cat.
  8. #28 Re: Need help with a P0300 code
    good test for a cat there.
  9. #29 Re: Need help with a P0300 code
    Nov 2017
    Utah
    Just tried it. Still missing really bad. The car actually died when I was pulling it back into my apartment's parking lot, though that may have been because it was missing the sensor lol
  10. #30 Re: Need help with a P0300 code
    Nov 2017
    Utah
    I found a new clue. When I start the car, it will idle normally at first. Then, after a minute or so, the idle increases to around 1300 RPM and it starts misfiring. Is this the EGR turning on or something else the computer does shortly after starting the car?
  11. #31 Re: Need help with a P0300 code
    Nov 2017
    Utah
    I think I figured it out. When I swapped the transmission, there was one ground on the transmission toward the front of the car under the front manifold/crossover pipe connection that I apparently did not tighten down enough. I guess the connection was flaky enough to cause electrical issues, which would explain why my misfire was intermittent. Once I got the nut holding the grounding wires tightened down properly, I had zero misfiring. Stupid simple fix.
  12. #32 Re: Need help with a P0300 code
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Thank You.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  13. #33 Re: Need help with a P0300 code
    the old loose ground cable strikes again lol glad to hear it was a free fix in the end.
  1. Relentless P0300 code
    By gofast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2016, 08:50 AM
  2. P0300 code , need help !!
    By damohr in forum General Tech Discussion
    Last Post: 03-04-2015, 07:44 PM
  3. someone help? p0300 code
    By ericg1181 in forum General Tech Discussion
    Last Post: 04-07-2014, 02:09 PM
  4. Stumped with P0300 code
    By zach101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-20-2011, 04:56 PM
  5. 4-5k rpm misfire, Code P0300.
    By trailshredder in forum Engine
    Last Post: 11-13-2011, 07:43 PM
