Thread: Realistic Power Goals for bolt ons for a NA Series 3
Results 1 to 8 of 8
  1. #1 Realistic Power Goals for bolt ons for a NA Series 3
    Mar 2015
    Tampa, FL
    Not really up for a top swap and dont wanna have car payments yet. Im thinking about doing a bunch of ZZP bolt-ons, 1.9 rockers, HV3 intake insert. 2.5 catted down pipe along with front and rear headers. I have someone that can tune the car for me and for cheap. Is picking up 50-60 hp from these bolts-on a realistic goal? IS it better to go with 3" down pipe, it is cheaper.
  2. #2 Re: Realistic Power Goals for bolt ons for a NA Series 3
    not worth it, the hp returns are just not there. save up more money, turbo it, best bang for the buck.
  3. #3 Re: Realistic Power Goals for bolt ons for a NA Series 3
    Kemmerer, Wyoming
    you could do all that and still not pick up 50 hp. even a cam won't net that much hp.
  4. #4 Re: Realistic Power Goals for bolt ons for a NA Series 3
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Unfortunately agreed. There's not really many gains unless you're going to port your heads and upgrade the cam and hv3 insert, but yeah, even then you'd be lucky to pick up 40. Not worth it unless you're planning on going turbo.
  5. #5 Re: Realistic Power Goals for bolt ons for a NA Series 3
    Mar 2015
    Tampa, FL
    If that's the case id rather do a top swap. Or just swap in a whole engine
  6. #6 Re: Realistic Power Goals for bolt ons for a NA Series 3
    Kemmerer, Wyoming
    now you are talking
  7. #7 Re: Realistic Power Goals for bolt ons for a NA Series 3
    A decent cam swap with other stuff could get you near 200whp if everything was working with you. That's a gain of around 30-40hp.
    A lot of money for not much gain though.
  8. #8 Re: Realistic Power Goals for bolt ons for a NA Series 3
    Mar 2018
    NY
    Depends how far you want to take it. You can make the n/a fun to drive with things like the hv3, er rockers (or cam), ported exhaust manifolds (or headers) with u-bend delete and a reprogrammed PCM along with some other supporting mods, but if your looking to truly make power boost is the way to go. Our cars are heavy fat pigs
  1. Series 2 rods how much power can they handle
    By revin24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2014, 01:47 AM
  2. L26 swap in 96 SE would it be realistic
    By Dustindell in forum General Tech Discussion
    Last Post: 10-26-2013, 08:58 PM
  3. GTP Build. Sub 13 Second 300whp goals!
    By camopaint0707 in forum General Grand Prix Discussion
    Last Post: 05-29-2013, 03:07 PM
  4. Series 2 bellhousing bolt pattern?
    By oldschoolpontiacs in forum General Tech Discussion
    Last Post: 06-22-2009, 10:32 AM
  5. Goals for my gtp this summer
    Last Post: 02-16-2008, 02:24 PM
