Thread: 2008 Grand Prix 3.8 III Series Coolant leak
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 82
  1. #1 2008 Grand Prix 3.8 III Series Coolant leak
    Oct 2017
    CA
    So, I was pointed over here from Reddit and have read a bunch of threads about possible fixes but with variations of the motor and differences in configurations I thought I'd see if there is anything that I'm missing.
    2008 GP 3.8 III Series started overheating a couple of weeks ago. I've had the car for about a year (has 140k miles) and the heater has never worked, which I should have looked into when I got the car it seems. Gauge went into the red a couple of times and I pulled over right as the engine failsafe kicked in and got the car home once it was cool enough to limp a mile at a time.
    Once home I replaced the thermostat and water pump, flushed the coolant (ignored the heater elbows because they were metal and the leak was obviously coming from the water pump), bleed the air out and everything seemed good. Drove around town for 4 days without any issue. Then it started over heating again after about 10 miles of driving. Pulled over to the side of the freeway (yeah, I thought it was that fixed) and eventually made it home without driving in the red.
    Decided at that point to replace the LIM gasket. Didn't want to, but I did it (didn't use RTV though). Put in a new thermostat and flushed the coolant again and refilled it. Waiting for operating temp to bleed the air out and I notice it's leaking bad. Dumping out passenger side in front of the engine. Turn the engine off and hear hissing and a spray that stops before I can get around to the side to see where. Dripping continues with the engine off and I pour more coolant in to see if it'll drip and it does.
    So, last night I buy new heater elbows, figuring that there's nothing else it could be. Replace those after work today, refill the coolant and I'm not getting a drip with the engine off. Put the new thermostat in and start the engine. Seems fine for a minute or two and then I notice the leak is going again. Dripping pretty stead down the front of the engine off of a bolt that is directly in the middle of the crank shaft and a/c pullys. Which tells me it's higher than that but I can't get a good look or a good picture.
    Tonight I read for the first time about sealing the water pump bolts, but I was watching coolant drip out at a steady stream, "drip" isn't even a good word for it but "pour" seems a little extreme. I also read for the first time about the timing cover issue which sounds like a lot more work than I want to do at this point. I mean, I'll do it if that is where all signs are pointing but I won't be happy about it. So far I'm a few hundred into this and every day off I've had for two weeks. I don't have money to burn and have spent more than I want to, but I know I've spent less than I would have at a shop for pretty much anything I've done so far.
    Help please!!
  2. #2 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    hard to say, post some pics of the leak area. sounds like the timing cover might be cracked, or the gasket failed.
  3. #3 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I would unfortunately wager money that it's the timing cover. Not a fun job and takes a bit of work to do. Cleaning old gasket material and correctly sealing oil pan with rtv is one of the hardest parts, but the worst is when people don't prime the pumps upon removal of the timing cover. I'd check to see if re- priming is needed and if so pack with Vaseline (I know, sounds crazy, but machinists of over 30+ years experience do this and I have for two successful rebuilds of this engine).
    I would check to see if your heater core is restricted as this can cause the gasket to blow.
    Mine did this because some idiot mixed dex and green together!
    Good luck!
  4. #4 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    Oct 2017
    CA
    2008 Grand Prix 3.8 III Series Coolant leak Attached Images
  5. #5 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    Oct 2017
    CA
    That's as good as I could get. I'll try again tomorrow. It was dark when I ended for the night.
  6. #6 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    Oct 2017
    CA
    Quote Originally Posted by wstefan20 View Post
    Good luck!
    I'm thinking the heater core is good because when I first thought I had it fixed it was blowing hot air like a champ, which had me pretty confident that I had done a perfect job.
    Forgive my ignorance but I'm not sure what you mean by "prime the pump" when it comes to this. I'm used to the idea of putting a little bit of fuel in a chamber prior to trying to start an engine after being dry, but I don't get what you mean here or why Vaseline would be used or where it would be used at.
  7. #7 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    how far up is it wet? almost to the top of the cover? being the block is wet it looks like gasket failure so far.
  8. #8 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    Oct 2017
    CA
    I think it's wet to right below the water pump. I'll double check again in the morning. I was pretty sure I finally had it figured out before I replaced the elbows that I didn't take pics today.
    When you say "gasket" do you mean the timing cover gasket or the LIM one again?
  9. #9 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    timing cover gasket. when it over heated on you it likely blew out. or if it looks to be coming out the bolt you can try taking the bolt out and putting thread sealant on the threads.
    the 4 long water pump bolts need sealant too. they could be leaking as well if you didnt use new sealant on them. most of the timing cover bolts go through the the block into the water jackets of the block. so re seal em all should you end up taking the cover off.
    if you get a couple cans of brake cleaner it will dry up that whole leak area and change its color some, this way you can see the trail better when you fire it up.
  10. #10 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    Oct 2017
    CA
    Damn, I was hoping you'd say water pump, lol.
    Okay, in the morning I'll go out and get a couple cans of brake cleaner and some sealant. Seal the bolts in the water pump, clean the engine as well as I can with brake cleaner and start over to see where it is leaking.
  11. #11 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    Oct 2017
    CA
    Another fact that might be helpful: my oil seems to be clean. I thought I was getting a little steam out of the dipstick tube when it first overheated, but that might have just been from the engine since the oil has not appeared milky at all.
  12. #12 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    My scale of leak severity goes like this. (least to worst) lol
    Soak
    Seep
    Ooze
    Drip
    Dribble
    Piss
    Shoot
    Pour
    Spew
    Gush
    Puke
    Dump
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  13. #13 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    Aug 2017
    Raytown, MO
    I agree with Scotty. If the timing cover gasket is leaking where I think it is, there would be no mixing of oil and water so just because your oil is clear does not mean you are out of the blue. It might be worth trying Scotty's advice of sealing the threads and heads of the water pump bolts. MAKE SURE you actually have a correct torque wrench when re-tightening them. I'm a big fan of the felpro water pump and timing cover gasket btw. Helps with the bolt seal leakage issue too.
    Sorry about the confusion of priming the oil pump. I was remembering when I removed the oil pump, which might be a worthwhile "while you're in there" thing to do since it requires removal of the timing cover anyhow. I'd also replace the crankshaft main seal since it usually comes in the felpro kit anyways at most auto part stores. Just make sure you clean everything very well and use good rtv along the pan. What I was referring to is if you remove the oil pump for inspection, unlike the old pumps that can be spun with a drill to "suck up" or prime the oil (get rid of air that would cause pump to cavitate and not suck up oil), ours have to have some help. Your choices on this are either to remove the oil pump cover and pack it (literally just smear it in there) with petroleum jelly, and replace cover, or to remove the oil sender sensor and find a barb fitting that will fit and attach fitting with hose running to funnel and then use the starter (with coil pack and pump relay disconnected) to spin the engine to work up oil pressure. I've used both ways, but found the first is much easier and works well. Don't worry about the jelly, it melts within seconds and is harmless and will come out with your next oil change.
  14. #14 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    i didnt pack my pump. popped it all back on after cleaning it of course, then plugs out i cranked the piss out of it for 10, 10 second cranks.
    i was also dealing with a bone dry engine, so you should be ok with 3-5 cranks to get the oil flowing. plugs out it spins much faster and easier. and of course it cant fire up on you.
  15. #15 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    Aug 2017
    Raytown, MO
    personally, having rebuilt these engine's from scratch, I really wouldn't recommend this. It obviously can work, but you 1. Run the risk of the pump cavitating (won't suck oil because there's air trapped) and 2. Running your bearings dry for a moment, which you usually can't hear or see, and won't cause issues immediately but could cause issues down the road and premature bearing wear.
    The saying "better safe than sorry" comes into play, and for a few minutes of time and $1 Of Vaseline, there's really no reason not to.
    There's a reason that factories, machine shops, and mechanics all do this.
    Again not saying it's mandatory, just highly advised. If you don't remove your pump cover, then there should be enough left in there.
  16. #16 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    if you fill the filter its got something to suck up asap. and no spark plugs theres no compression. all spins like butter, and his engines not dry. its all lubed up. hell in theory he could just fire it up and let it idle really and be just fine.
  17. #17 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    Aug 2017
    Raytown, MO
    I agree with you if he does not remove the oil filter or pump cover, but I've seen first hand the affect of the pump cavatating and spinning bearings.
    Again, the importance goes up the more oil is removed, everyone has their opinions and mine is better safe than sorry!
  18. #18 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    Oct 2017
    CA
    New pictures after taking the water pump off. Figured I'd share these to see if anything new presents itself before I replace the timing chain gasket.
    Above water pump.
  19. #19 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    Oct 2017
    CA
    Inside water pump/timing chain cover connection.
  20. #20 Re: 2008 Grand Prix 3.8 III Series Coolant leak
    Oct 2017
    CA
    I think I'm going to skip the oil filter and pump cover on this adventure. I'd just as soon keep the complications to a minimum.
  1. 96 Grand Prix 3.1 Coolant leak
    By lightwalker in forum General Grand Prix Discussion
    Last Post: 04-03-2017, 07:57 PM
  2. 08 Grand Prix mystery coolant leak
    By mikegmoney in forum General Grand Prix Discussion
    Last Post: 03-15-2017, 04:54 AM
  3. Coolant leak on 2002 Grand Prix GT 3800
    By whiteta in forum General Grand Prix Discussion
    Last Post: 09-12-2014, 05:16 PM
  4. 2000 Grand Prix coolant leak
    By Rjsleeper in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-03-2013, 12:04 PM
  5. 93 Grand Prix stalling, running hot, coolant leak
    By thehollowaytape in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-07-2011, 10:46 PM
