Thread: fans not turning on until 220
Results 1 to 9 of 9
  1. #1 fans not turning on until 220
    Mar 2013
    maryland
    Hell all. My fans are not turning on until 220 and turn off at 208-210 degrees . Car is stock. Any help would be great
  2. #2 Re: fans not turning on until 220
    so you got a 04 up right? normal.
  3. #3 Re: fans not turning on until 220
    Mar 2013
    maryland
    99 gt
  4. #4 Re: fans not turning on until 220
    Still almost normal.
    Should be like 212 and 226 for the fans on temps with off temps are 207/223 or somthing very close.
    It's not over heating by any means at 210-220ยบ just sitting still.
  5. #5 Re: fans not turning on until 220
    Mar 2013
    maryland
    doesnt stay there goes from 223 to 208ish but goes right back up to 223ish
  6. #6 Re: fans not turning on until 220
    Mar 2013
    maryland
    the picis where it cools down to but goes a lil above that 3rd long line
  7. #7 Re: fans not turning on until 220
    Mar 2013
    maryland
  8. #8 Re: fans not turning on until 220
    I wouldn't just start throwing money at it but you may have coolant flow problems.
    A weak pump, really old coolant, partially blocked radiator. Also if you've never cleaned out the fins on the radiator that would be a good idea, tons of debris could be hurting it's ability to remove heat from the coolant.
    Again those temps aren't bad as it's not overheating but maybe some things could be looked at.
  9. #9 Re: fans not turning on until 220
    Mar 2013
    maryland
    thks pump is 5yrs old coolant is new stat is new was cooling fine when i had the zzp l36 sc kit on it stayed at constant 185. put the car back to stock na and now its doing this
  1. Power Steering Stiff turning wheel Left Normal turning wheel right.
    By AdrianGTP in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2017, 04:39 PM
  2. Cooling Fans Not Turning ON
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2013, 09:22 PM
  3. Turning the Cooling Fans on all the time
    By ls1camino in forum General Grand Prix Discussion
    Last Post: 09-21-2012, 08:18 AM
  4. fans fans fans
    By copperpacecar in forum General Tech Discussion
    Last Post: 11-03-2011, 08:44 AM
  5. FANS
    By robblk04 in forum General Tech Discussion
    Last Post: 03-05-2011, 04:49 PM
