Thread: Bad gas mileage help
Results 41 to 60 of 70
  1. #41 Re: Bad gas mileage help
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    My 04 has a "door", behind the rear seat, under all the trunk carpeting. It's almost directly in front of the spare tire well, but it's got 8 bolts holding it down and appears to be tack welded... unless the factory installed it with sealant goop BEFORE painting the body... lol
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  2. #42 Re: Bad gas mileage help
    Jan 2017
    Canada
    K thanks ill rip the car seat out later and have a look when the sun comes out if i get bad fuel pressure.
  3. #43 Re: Bad gas mileage help
    Jan 2017
    Canada
    Does anybody know what the maf readings should be at idle and throttle. My app has g/s
  4. #44 Re: Bad gas mileage help
    maf wont tell you any thing. watch the long term fuel trims.
  5. #45 Re: Bad gas mileage help
    Oct 2014
    Frederick, MD
    Maf is just for the PCM so it can keep the air-fuel ratio.
  6. #46 Re: Bad gas mileage help
    How's the downstream o2?
  7. #47 Re: Bad gas mileage help
    Jan 2017
    Canada
    Well long term is 15ish negative at cruise and negative 7 at throttle.
    Short term bounces from plus 5 to neg 5
  8. #48 Re: Bad gas mileage help
    Jan 2017
    Canada
    The down stream o2 ...check the volts?
    The up o2 sensor 1 is bouncing from 0.065 to 700ish
    The o2 sensor 2 is holding at 0.680 to 0.700
  9. #49 Re: Bad gas mileage help
    Have you checked for vacuum leaks? It's kind of odd that your LTFT are so out of wack and no cel.
    And how old is the rear o2 I mean, if it is as old as the front one you never know. And to be honest I have no idea if that is normal readings for o2 sensors.
  10. #50 Re: Bad gas mileage help
    Jan 2017
    Canada
    Thats kinda what ive been think maybe a vac leak....which should i spray around all the lines and any where else like hidden spots i should try and spray....carb cleaner i think right
  11. #51 Re: Bad gas mileage help
    Jan 2017
    Canada
    I have also noticed a rumbling idle ..kinda shakes the car lightly... And when i start AND shut off the car it feels like a rumble shake as well
  12. #52 Re: Bad gas mileage help
    Yup carb cleaner.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  13. #53 Re: Bad gas mileage help
    Jan 2017
    Canada
    All i had was maf cleaner. Didnt notice any changes with the idle. The app has a vac pressure widget. Would i get a good reading from that? If so what should it be. Or the fuel pressure gages at the auto store does fuel and vacume i belive.
    This is driving me crazy and killing my wallet. I watched pretty much a quarter tank go in two days only driving 25-30 kms
  14. #54 Re: Bad gas mileage help
    Jan 2017
    Canada
    On the emmissions test on the torque app it says its all good except the evaporative system incomplete ?related
  15. #55 Re: Bad gas mileage help
    evap can take forever to be "ready" gas level needs to drop past 1/2 a tank or some bs as part of its test.
  16. #56 Re: Bad gas mileage help
    Jan 2017
    Canada
    That sucks, i thought i was on to something
  17. #57 Re: Bad gas mileage help
    GTP Level Member
    springfield IL
    i cleaned out my fuel tank in 11' and have put a new fuel filter (wix) on twice since... instantly noticed a difference!!
    00" GT stock, still get 20mpg ish in town driving
  18. #58 Re: Bad gas mileage help
    Jan 2017
    Canada
    Im not to sure im gunna drop the tank out just yet. I want to order this tester for fuel and vacume. Would this one work OTC 5613 ...on amazon.com. But it only says low fuel pressure on the fuel side of it.
    I have this feeling that everytime i start the car ive watched it drop. Does it check high fuel pressure? Or im i sniffing glue sticks.....
    And does anybody think that the rumbly starts and some what shaky idles have anything to do with the fuel being eaten up. Also the rumbly shaky when i turn the car off.
  19. #59 Re: Bad gas mileage help
    SE Level Member Billycar11's Avatar
    Apr 2015
    Pa
    just as a point of reference in torque my vacuum gauge hovers around -19 - -20 at idle i have an 07 na
  20. #60 Re: Bad gas mileage help
    Jan 2017
    Canada
    Same as mine according to this app....i wonder whats causing this poor fuel issue
  1. Gas mileage...
    By mick777wauchope in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2012, 07:35 PM
  2. gas mileage ???
    By v8teezr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2011, 07:13 PM
  3. Why am I getting bad Gas Mileage?
    By JDCMoney in forum General Tech Discussion
    Last Post: 06-10-2010, 01:34 PM
  4. bad gas mileage
    By Joe m in forum General Tech Discussion
    Last Post: 02-03-2010, 02:17 PM
  5. Better mileage on an old V8 than a GTP LoL!
    By Juanmiguel in forum The Rant Forum
    Last Post: 01-28-2010, 09:26 PM
